Home » Archived » Test and Performance Tools Platform (TPTP) » AGR stacktraces but testcase passes
AGR stacktraces but testcase passes [message #121958] Mon, 04 February 2008 11:49 Go to next message
Originally posted by: stephanl.us.ibm.com
Greetings,
I am running AGR v4.3.0 in WebSphere Integration Developer v6.1.0, which
is built on Eclipse 3.2. I am executing a single, simple AGR testcase by
invoking it programmatically from ant as follows:
<target name="CreateConfigurationAndProject" description="Execute">
<tptp:test
resultsrefid="tptp.test.results"
workspace="${test.root.dir}\dev-ws"
project="com.webify.wsf.studio.test"
suite="test-suites/CreateConfigurationAndProject.testsuite"
synchronicity="synchronous"
vmargs="-Dagr.exe.ws=${test.root.dir}\exe-ws"
</target>
While the test completes successfully, I am seeing the below stacktrace in
the console from which I invoke AGR. The test does not contain any
assertions. Any idea/input what is causing this stacktrace would be much
appreciated. I am unsure if
Thanks!
- Stephan
CreateConfigurationAndProject:
Test started!
Test '\test-suites\CreateConfigurationAndProject.testsuite' executing
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:150)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:126)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:273)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:288)
org.eclipse.jface.resource.JFaceResources.getFontRegistry(JF aceResources.java:267)
org.eclipse.jdt.internal.ui.JavaPlugin.uninstallPreferenceSt oreBackwardsCompatibility(JavaPlugin.java:477)
at org.eclipse.jdt.internal.ui.JavaPlugin.stop(JavaPlugin.java: 526)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:35)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
java.security.AccessController.doPrivileged(AccessController .java:242)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:342)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:88)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:412)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:569)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get Extension(ExtensionsRegistry.java:241)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.doG etDocumentSetupParticipants(ExtensionsRegistry.java:364)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get DocumentSetupParticipants(ExtensionsRegistry.java:386)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get DocumentSetupParticipants(ExtensionsRegistry.java:519)
org.eclipse.core.internal.filebuffers.TextFileBufferManager. createEmptyDocument(TextFileBufferManager.java:305)
org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .initializeFileBufferContent(ResourceTextFileBuffer.java:268 )
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:242)
org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:108)
org.eclipse.pde.internal.core.builders.ErrorReporter.createD ocument(ErrorReporter.java:71)
org.eclipse.pde.internal.core.builders.BuildErrorReporter.pr epareTextBuildModel(BuildErrorReporter.java:438)
org.eclipse.pde.internal.core.builders.BuildErrorReporter.va lidate(BuildErrorReporter.java:108)
org.eclipse.pde.internal.core.builders.ErrorReporter.validat eContent(ErrorReporter.java:130)
org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.checkBuildProperties(ManifestConsistencyChecker.java:1 40)
org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.checkThisProject(ManifestConsistencyChecker.java:58)
org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.build(ManifestConsistencyChecker.java:40)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:603)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:167)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:230)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:233)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:252)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:285)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:154)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Waiting..................................................... ............................................................ .........................
Collected results:
'org.eclipse.hyades.models.common.testprofile.impl.TPFExecut ionResultImpl @96e096e
(eProxyURI:
platform:/resource/com.webify.wsf.studio.test/CreateConfigur ationAndProject.execution#E0E2C7A2B9F99298E2FA3710868A11DC)'
Test '\test-suites\CreateConfigurationAndProject.testsuite' completed
Test completed!
Re: AGR stacktraces but testcase passes [message #122039 is a reply to message #121958] Mon, 04 February 2008 13:06 Go to previous messageGo to next message
Hi Stephan,
The exception is thrown since the JFace code cannot find the display.
Is this on Linux? If so, the problem is mostly caused by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216635. Can you try exporting
the DISPLAY?
Paul
"Stephan Lips" <stephanl@us.ibm.com> wrote in message
news:15ecd753da2dd50faa4c832bef508fb8$1@www.eclipse.org...
> Greetings,
> <tptp:test
> </target>
> Thanks!
> - Stephan
> Test started!
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(AccessController .java:242)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Collected results:
> (eProxyURI:
> Test completed!
Re: AGR stacktraces but testcase passes [message #122091 is a reply to message #122039] Mon, 04 February 2008 15:57 Go to previous messageGo to next message
Thanks Paul. This is actually on Windows XP, with the display in plain
view in front of me :) (well, desktop, logged on). Any ideas what could
be causing this on Windows? Apologies for not including the platform/OS
in the original posting.
- Stephan
Paul Slauenwhite wrote:
> Hi Stephan,
> the DISPLAY?
> Paul
>> Greetings,
>> <tptp:test
>> workspace="${test.root.dir}dev-ws"
>> vmargs="-Dagr.exe.ws=${test.root.dir}exe-ws"
>> </target>
>> Thanks!
>> - Stephan
>> Test started!
>> Test 'test-suitesCreateConfigurationAndProject.testsuite' executing
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Collected results:
>> (eProxyURI:
>> Test 'test-suitesCreateConfigurationAndProject.testsuite' completed
>> Test completed!
Re: AGR stacktraces but testcase passes [message #122171 is a reply to message #122091] Tue, 05 February 2008 06:29 Go to previous message
Hi Stephan,
No, I do not when running on Windows. Since the local Eclipse instance
is headless, I am not really sure why the JFace code would want to find the
display. Please add a comment with the details to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216635 and we will investigate
further.
Paul
news:da474a51a45d06b06960888e93653469$1@www.eclipse.org...
> - Stephan
>> Hi Stephan,
>> exporting the DISPLAY?
>> Paul
>>> Greetings,
>>> by invoking it programmatically from ant as follows:
>>> <tptp:test
>>> </target>
>>> in the console from which I invoke AGR. The test does not contain any
>>> much appreciated. I am unsure if
>>> Thanks!
>>> - Stephan
>>> Test started!
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Collected results:
>>> (eProxyURI:
>>> Test completed!
Previous Topic:Importing JUnit Tests into a TPTP JUnit Test
Next Topic:ArrayIndexOutofBoundsException
Current Time: Mon Jul 21 22:16:21 EDT 2025
Powered by FUDForum. Page generated in 0.03101 seconds
