| AGR stacktraces but testcase passes [message #121958] |
Mon, 04 February 2008 11:49  |
Originally posted by: stephanl.us.ibm.com
Greetings,
I am running AGR v4.3.0 in WebSphere Integration Developer v6.1.0, which
is built on Eclipse 3.2. I am executing a single, simple AGR testcase by
invoking it programmatically from ant as follows:
<target name="CreateConfigurationAndProject" description="Execute">
<tptp:test
resultsrefid="tptp.test.results"
workspace="${test.root.dir}\dev-ws"
project="com.webify.wsf.studio.test"
suite="test-suites/CreateConfigurationAndProject.testsuite"
synchronicity="synchronous"
vmargs="-Dagr.exe.ws=${test.root.dir}\exe-ws"
</target>
While the test completes successfully, I am seeing the below stacktrace in
the console from which I invoke AGR. The test does not contain any
assertions. Any idea/input what is causing this stacktrace would be much
appreciated. I am unsure if
Thanks!
- Stephan
CreateConfigurationAndProject:
Test started!
Test '\test-suites\CreateConfigurationAndProject.testsuite' executing
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:150)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:126)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:273)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:288)
org.eclipse.jface.resource.JFaceResources.getFontRegistry(JF aceResources.java:267)
org.eclipse.jdt.internal.ui.JavaPlugin.uninstallPreferenceSt oreBackwardsCompatibility(JavaPlugin.java:477)
at org.eclipse.jdt.internal.ui.JavaPlugin.stop(JavaPlugin.java: 526)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:35)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
java.security.AccessController.doPrivileged(AccessController .java:242)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:342)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:88)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:412)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:569)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get Extension(ExtensionsRegistry.java:241)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.doG etDocumentSetupParticipants(ExtensionsRegistry.java:364)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get DocumentSetupParticipants(ExtensionsRegistry.java:386)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get DocumentSetupParticipants(ExtensionsRegistry.java:519)
org.eclipse.core.internal.filebuffers.TextFileBufferManager. createEmptyDocument(TextFileBufferManager.java:305)
org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .initializeFileBufferContent(ResourceTextFileBuffer.java:268 )
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:242)
org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:108)
org.eclipse.pde.internal.core.builders.ErrorReporter.createD ocument(ErrorReporter.java:71)
org.eclipse.pde.internal.core.builders.BuildErrorReporter.pr epareTextBuildModel(BuildErrorReporter.java:438)
org.eclipse.pde.internal.core.builders.BuildErrorReporter.va lidate(BuildErrorReporter.java:108)
org.eclipse.pde.internal.core.builders.ErrorReporter.validat eContent(ErrorReporter.java:130)
org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.checkBuildProperties(ManifestConsistencyChecker.java:1 40)
org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.checkThisProject(ManifestConsistencyChecker.java:58)
org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.build(ManifestConsistencyChecker.java:40)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:603)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:167)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:230)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:233)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:252)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:285)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:154)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Waiting..................................................... ............................................................ .........................
Collected results:
'org.eclipse.hyades.models.common.testprofile.impl.TPFExecut ionResultImpl @96e096e
(eProxyURI:
platform:/resource/com.webify.wsf.studio.test/CreateConfigur ationAndProject.execution#E0E2C7A2B9F99298E2FA3710868A11DC)'
Test '\test-suites\CreateConfigurationAndProject.testsuite' completed
Test completed!
| Re: AGR stacktraces but testcase passes [message #122091 is a reply to message #122039] |
Mon, 04 February 2008 15:57   |
Thanks Paul. This is actually on Windows XP, with the display in plain
view in front of me :) (well, desktop, logged on). Any ideas what could
be causing this on Windows? Apologies for not including the platform/OS
in the original posting.
- Stephan
Paul Slauenwhite wrote:
> Hi Stephan,
> The exception is thrown since the JFace code cannot find the display.
> Is this on Linux? If so, the problem is mostly caused by
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=216635. Can you try exporting
> the DISPLAY?
> Paul
> "Stephan Lips" <stephanl@us.ibm.com> wrote in message
> news:15ecd753da2dd50faa4c832bef508fb8$1@www.eclipse.org...
>> Greetings,
>> <tptp:test
>> workspace="${test.root.dir}dev-ws"
>> vmargs="-Dagr.exe.ws=${test.root.dir}exe-ws"
>> </target>
>> Thanks!
>> - Stephan
>> Test started!
>> Test 'test-suitesCreateConfigurationAndProject.testsuite' executing
>> at
>> at
>> at
>> at
>> at java.security.AccessController.doPrivileged(AccessController .java:242)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Collected results:
>> (eProxyURI:
>> Test 'test-suitesCreateConfigurationAndProject.testsuite' completed
>> Test completed!
| Re: AGR stacktraces but testcase passes [message #122171 is a reply to message #122091] |
Tue, 05 February 2008 06:29  |
Hi Stephan,
No, I do not when running on Windows. Since the local Eclipse instance
is headless, I am not really sure why the JFace code would want to find the
display. Please add a comment with the details to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216635 and we will investigate
further.
Paul
news:da474a51a45d06b06960888e93653469$1@www.eclipse.org...
> - Stephan
>> Hi Stephan,
>> exporting the DISPLAY?
>> Paul
>>> Greetings,
>>> by invoking it programmatically from ant as follows:
>>> <tptp:test
>>> </target>
>>> in the console from which I invoke AGR. The test does not contain any
>>> much appreciated. I am unsure if
>>> Thanks!
>>> - Stephan
>>> Test started!
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Collected results:
>>> (eProxyURI:
>>> Test completed!
FUDForum. Page generated in 0.04672 seconds
