"Plug-in Project" does not display in the New Project Wizard [message #121955] |
Mon, 05 December 2005 21:33 |
I'm new to eclipse and am playing around with Eclipse and Linux at home.
I'm using the Eclipse that came bundled with Fedora Core 4. It is version
3.1.1, and I'm Java SDK version 1.5.0_05.
I'm trying to create a "Hello World" type plugin, but get stuck creating
the project. In the first window of the New Project Wizard, there is no
"Plug-in Project" option to select. The options are C, C++, Java, CVS, and
Simple. Under the Java selection there is "Java Project" and "Create
project from Existing Ant Build File".
I've created regular Java projects with this installation with no problem.
If I use the help installed with Eclipse, it has info on creating a
plugin project, so I assume I don't have to download anything, but not
sure.
Thanks for your help.
-Joe
FUDForum. Page generated in 0.08128 seconds
