Home » Language IDEs » C / C++ IDE (CDT) » Call relation among functions/methods
Call relation among functions/methods [message #121943] Tue, 28 September 2004 06:04 Go to next message
I'm new to Eclipse CDT. I'm trying to develop a small tool that can
extract call relation among functions/methods. Can anybody help me on this
?. Thanks for your time
Re: Call relation among functions/methods [message #122182 is a reply to message #121943] Wed, 29 September 2004 14:28 Go to previous messageGo to next message
You can implement ISourceElementRequestor and do a complete parse and watch
for the enter/exit function/method callbacks along with the acceptReference
callback.
Look at MatchLocator to see how search does something similar.
-Andrew
"ganesan" <ganesan@iese.fhg.de> wrote in message
news:cjbcv7$cq7$1@eclipse.org...
Re: Call relation among functions/methods [message #124983 is a reply to message #122182] Mon, 25 October 2004 09:48 Go to previous messageGo to next message
Thanks for your reply. I tried your suggestion to extract call graph from
a c file. I have a few problems in extracting call graph for a small piece
of "C" code, placed below. I have commented the problem within the code
itself. Ofcourse, my Java code which queries the Parser is also placed
below. Please let me know whether this is a problem in CDT or in my Java
code.
To extract call graph, I store the currently entered function and keep
track of list of functions that were referenced. But, I miss a few calls
(Please refer my "C" code).
class CMySourceElementRequestor extends StructuralParseCallback {
private String inputFileName = null; // file to be parsed
private String currentlyEnteredFunction = null; // name of function that
is currently entered
public CMySourceElementRequestor(File inputFileName){
this.inputFileName = inputFileName.getAbsolutePath();
public void acceptFunctionReference( IASTFunctionReference reference ) {
// function calls other functions
System.out.println("call " + currentlyEnteredFunction + " " +
reference.getName());
public void enterFunctionBody(IASTFunction function) {
currentlyEnteredFunction = function.getName();
public void exitFunctionBody(IASTFunction function) {
System.out.println("**** Exiting function body: " + function.getName());
function.setHasFunctionBody(true);
public boolean parserTimeout() {
return false;
public boolean acceptProblem( IProblem problem ) {
System.out.println("Parsing problem: " + problem.getMessage());
System.out.println("Problem at line: " + problem.getSourceLineNumber());
String src = new String(problem.getOriginatingFileName());
System.out.println("Originating problem in file: " + src);
return true;
public class TestCallGraph {
private final static String[] incPaths = getIncludePaths();
private File srcFile; // C file to be parsed
private CMySourceElementRequestor mySourceElementRequestor;
public TestCallGraph(File srcFile) {
this.srcFile = srcFile;
mySourceElementRequestor = new CMySourceElementRequestor(srcFile);
private static String[] getIncludePaths() {
String[] incPaths = new String[2];
incPaths[0] = "C:\\cygwin\\usr\\include";
incPaths[1] = "C:\\cygwin\\lib\\gcc-lib\\i686-pc-cygwin\\3.3.1\\include";
return incPaths;
public void printCallGraph() {
IScanner myIScanner;
IParser myIParser;
/* Create a Scanner */
myIScanner = ParserFactory.createScanner(
InternalParserUtil.createFileReader(srcFile.getAbsolutePath( )),
srcFile.getAbsolutePath(), new ScannerInfo(null, incPaths),
ParserMode.COMPLETE_PARSE, ParserLanguage.C,
mySourceElementRequestor, null, null);
/* Create a Parser */
myIParser = ParserFactory.createParser(myIScanner,
mySourceElementRequestor, ParserMode.COMPLETE_PARSE,
ParserLanguage.C, null);
if (myIParser.parse() == true) {
System.out.println("Parse successful for file: " +
srcFile.getAbsolutePath());
} else {
System.out.println("Parse unsuccessful for file: " +
/* Main program */
if(args.length < 1) {
System.out.println("Usage: java TestCallGraph <absolute path to a .c
file>");
TestCallGraph callGraph = new TestCallGraph(new File(args[0]));
callGraph.printCallGraph();
/* Test case for call graph extractor */
#include <string.h>
typedef char ECHAR;
void myFunction()
ECHAR * str = (ECHAR *)"X";
ECHAR * str2 = (ECHAR *)"XX";
char * cStr = "Y";
/* myFunction calling strlen - This works correctly */
strlen(str);
/* myFunction calling strlen using ECHAR is completely missing - NOT
Working*/
if(strlen(str) + strlen(str2) <= 3) { };
/* myFunction calling strlen using cStr - This works correctly */
//if (strlen(cStr) + strlen(cStr)) { };
Thanks for your time.
Dharma
> callback.
> -Andrew
> > Hi,
Re: Call relation among functions/methods [message #125009 is a reply to message #124983] Mon, 25 October 2004 11:56 Go to previous message
Hi Dharma,
It looks like there is a bug in the parser that is causing ECHAR * str =
(ECHAR *) "X";
to be parsed as an expression instead of as a declaration.
Until this is fixed, you can get around this problem by changing your
declaration of ECHAR:
typedef char * ECHAR;
ECHAR str = (ECHAR)"X";
-Andrew
"dharmalingam ganesan" <ganesan@iese.fhg.de> wrote in message
news:clj06r$51q$1@eclipse.org...
> code.
> return false;
> return true;
> return incPaths;
> IParser myIParser;
> } else {
> /* Main program */
> public static void main(String[] args) {
> file>");
> #include <string.h>
> typedef char ECHAR;
> void myFunction()
> char * cStr = "Y";
> strlen(str);
> Working*/
> Dharma
watch
acceptReference
> > callback.
> > -Andrew
> > > Hi,
this
Previous Topic:Call relation among functions/methods
Next Topic:Just my C++ projects in the C/C++ Projects
Current Time: Fri Jul 18 12:59:28 EDT 2025
Powered by FUDForum. Page generated in 0.05256 seconds
