Contribution to TPTP [message #121879] |
Mon, 04 February 2008 05:06  |
Hi TPTP project members,
we (brox and empolis) are currently propsing a eclipse project called EILF
(http://www.eclipse.org/proposals/eilf/).
Our project has the area of information management and we are using TPTP for
measureing performance.
We have developed an extension that matches the M$ approach of performance
counters.
http://www.developer.com/net/net/article.php/3356561
These performance counters could be embedded into the application via OSGi
bundles.
We are planing to use these components for application monitoring in our
software.
Is your team interested in a contribution?
Georg Schmidt
Re: Contribution to TPTP [message #122131 is a reply to message #122078] |
Tue, 05 February 2008 04:49  |
Hi Oliver,
thanks to your response. I will contact the COSMOS team also.
Indeed we are monitoring production systems... But also during development
and configuration modifcation. Performance engeneering in general... its
starting in the development.... (who i have to tell ;-) you are much more in
than i ) I mean... gathering method level metrics is not all and it should
be concidered on a higher level. Take a look onto the performance counters
of your OS (when you are using windows). I want to have this feature
seamlessly in any application. I wan't to be able to optimize in any level
of the application lifecycle [dev; test; configuration; deployment;
production;]... and TPTP is making the connection to OS and the hardware
area.
We have spend some month to get it running...
I got into touch with your project cause of the following reasons.
* We are using TPTP for monitoring the OS
* We have made an Agent (i am not the tech guy who made it... please correct
me if incorrect) that is able to collect data from the performance counters
* We are now able to do what we have done before in .NET (but better)...
creating a relationship between our app and the OS
* I wanted to give something back.
Georg
"Oliver E Cole" <oec@ocsystems.com> wrote in message
news:fo7q05$bao$1@build.eclipse.org...
> Hi Georg:
> I am the TPTP PMC lead. A tough job, let me tell you......
> Looks like you all are attacking a big problem area. I think that the
> alignment might be better with COSMOS rather than TPTP. Your project
> seems to be targeted to monitoring of the actual production system,
> whereas TPTP is more focused on the test areas: pre-production.
> Certainly, some of our measurement software could be used by you, but TPTP
> is not heading in the direction of monitoring a production system.
> We could probably get someone to chat to you regarding specific things
> that you would like from TPTP.
> --oec
>> EILF (http://www.eclipse.org/proposals/eilf/).
>> for measureing performance.
>> performance counters.
>> OSGi bundles.
>> software.
>> Regards,
>> Georg Schmidt
FUDForum. Page generated in 0.06133 seconds
