Home » Eclipse Projects » Eclipse Platform » Editor and multiple editor input
Editor and multiple editor input [message #121782] Wed, 03 September 2003 05:39 Go to next message
Originally posted by: didier.besset.ch.sogeti.biz
The editor I am working on is editing a group of files as one unit. One of
the files for the set is the "main" file and is set to the editor input
when an editor is openeed an any of the other files.
The problem occurs when one opens a file for that set other than the
"main" file, a new editor is opened because the algorithm determining what
is the editor input (IEditorInput) is within the editor itself.
Questions: Is there a way to tell Eclipse that the editor input is a set
of files (but better than a folder since the files can be located
anywhere)? Alternatively, is there a way to notify within the method
init(IEditorSite,IEditorInput) that no new instance must be created and
control should be passed to another instance of the same editor?
Didier
Re: Editor and multiple editor input [message #122179 is a reply to message #121782] Wed, 03 September 2003 11:17 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
When the workbench page is asked to open an editor on an IEditorInput, it
check first if there is already an open editor for this input. The workbench
page uses "equals()" method to determine if the new input matches an
existing editor input. The code is something like this:
openEditor(IEditorInput input, ...) {
Iterator editors = getOpenEditors();
while (editors.hasNext()) {
IEditorPart editor = (IEditorPart) editors.next();
if (input.equals(editor.getInput())
Simon :-)
PS By the way, are you saying that in your init method, you ignore the
IEditorInput you were passed and instead create your own on this "main
file"? That is not part of the init method contract.
"Didier Besset" <didier.besset@ch.sogeti.biz> wrote in message
news:bj4ctd$na$1@eclipse.org...
> Cheers,
> Didier
Re: Editor and multiple editor input [message #122493 is a reply to message #122179] Thu, 04 September 2003 03:03 Go to previous messageGo to next message
Thanks for the reply!
Actually, I do use the "IEditorInput [I]were passed", but I then change it
with the following two lines of code:
setInput( new FileEditorInput( model.getResourceFile()));
firePropertyChange( PROP_INPUT);
(the "model" has been constructed from the IEditorInput passed and has
determined what is the "main" file to edit.
Following your suggestions, I made a class to wrap FileEditorInput and
added a suitable equals method. However, this method is called after the
window is opened, so that I still end up with two editor windows.
Any more suggestions?
Didier
> Simon :-)
> > Cheers,
> > Didier
Re: Editor and multiple editor input [message #122713 is a reply to message #122493] Thu, 04 September 2003 11:27 Go to previous messageGo to next message
A new editor is open only is none of the existing editor inputs do not
"equals()" the new input. There must be something else going on.
Simon :-)
news:bj6o4t$b32$1@eclipse.org...
> Cheers,
> Didier
it
workbench
> > Simon :-)
One of
input
what
set
and
> > > Cheers,
> > > Didier
Re: Editor and multiple editor input [message #123010 is a reply to message #122179] Fri, 05 September 2003 09:58 Go to previous messageGo to next message
Originally posted by: glongman.intelligentworks.nospam.com
Since this topic is close to a question I've had for a while...
Is there an implementation of MultiEditor out there one can look at?
And
Is there any way to intercept the openEditor() call and tweak the input?
I ask as I would be pleased as punch if my plugin could intercept the call,
examine its state and the input itself, then insome cases turn the input
into a MultiEditor input.
We have a similar case of related files and a MultiEditor (if I understand
it right) would be an excellent tool to use.
Geoff
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:bj50ks$nts$1@eclipse.org...
workbench
> Simon :-)
Re: Editor and multiple editor input [message #123087 is a reply to message #123010] Fri, 05 September 2003 10:42 Go to previous messageGo to next message
No and No
Simon :-)
"G Longman" <glongman@intelligentworks.nospam.com> wrote in message
news:bja4me$h66$1@eclipse.org...
> And
call,
> Geoff
it
> workbench
> > Simon :-)
Re: Editor and multiple editor input [message #123335 is a reply to message #123087] Fri, 05 September 2003 15:14 Go to previous messageGo to next message
> No and No
> Simon :-)
Why not? and I'll add a feature request!
Geoff
Re: Editor and multiple editor input [message #123348 is a reply to message #123335] Fri, 05 September 2003 15:15 Go to previous messageGo to next message
I do not know why. Open a feature request...
Simon :-)
news:bjan6n$4m9$1@eclipse.org...
> > No and No
> > Simon :-)
> Geoff
Re: Editor and multiple editor input [message #123558 is a reply to message #123335] Sat, 06 September 2003 05:06 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
You might search for an existing one. I think this is a perennial request.
Bob
> > No and No
> > Simon :-)
> Geoff
Re: Editor and multiple editor input [message #123571 is a reply to message #122713] Sat, 06 September 2003 05:11 Go to previous messageGo to next message
Sorry to insist, but have you tried this?
The code checking for equals get called indeed and it returns true.
Nevertheless the editor is opened again. So I am at a loss here. Actually,
if I can believe the print outs I peppered my code with orthe debugger, it
appears that the new editor is opened ***before*** the check for equality
between two IEditorInput is performed. There must be something to be done
before that...
Would you have a code example I can borrow and try out?
Has anyone have this problem before?
Didier
> Simon :-)
Re: Editor and multiple editor input [message #123613 is a reply to message #123558] Sat, 06 September 2003 16:51 Go to previous messageGo to next message
I did (search for MultiEditor in bug comments), and found 19 bugs related.
Of the 19, two are mine, one refers to MultiEditorPage (not the same thing)
and four more are only peripherally related. The remainder are reported by
ibm/oti people who obviously are "in the know".
One is interesting as it refers to a "Sample MultiEditor page". Where is
this sample?!?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=14408
Geoff
"Bob Foster" <bob@objfac.com> wrote in message
news:bjc766$5qr$1@eclipse.org...
> Bob
> > > No and No
> > > Simon :-)
> > Geoff
Re: Editor and multiple editor input [message #125497 is a reply to message #123571] Tue, 09 September 2003 10:42 Go to previous messageGo to next message
The code works - otherwise, you would see this problem with the java editor,
pde editor, etc
I suggest you step thru the code using the debugger to understand what is
going wrong. At very least, but a breakpoint in the equals() method to see
if the inputs being compared are yours. Also a breakpoint in your init
method of you editor to see on the stack who is calling it (i.e is it coming
from the openEditor() method), and what is the input being passed in (is it
yours)
Simon :-)
news:bjc8bl$6hr$1@eclipse.org...
> before that...
> Cheers,
> Didier
> > Simon :-)
Re: Editor and multiple editor input [message #125575 is a reply to message #125497] Tue, 09 September 2003 11:02 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
I don't know if this has anything to do with it but I think the
comparison using the equals may be backwards for your request.
Looking through the code EditorManager.findEditor(IEditorInput input),
which is used when seeing if an editor for "input" is already open. In
there the comparison is
input.equals(editorpart.getEditorInput())
From your description, the customized editor input is on the EditorPart
side of the equation. So in this compare it won't use your equals, but
instead uses the equals from the incoming IEditorInput, which is just a
standard IFileEditorInput.
Rich
Previous Topic:Opening a perspective (programmatically)
Next Topic:ResourceListSelectionDialog
Current Time: Tue Jul 22 19:47:25 EDT 2025
Powered by FUDForum. Page generated in 0.05333 seconds
