Home » Newcomers » Newcomers » Display Classes
Display Classes [message #121754] Mon, 05 December 2005 09:58
Originally posted by: kaboose72.hotmail.com
When I try and open a class file using Eclipse, I get the following error.
What do I need to do to view class files. I have
eclipse-SDK-3.1-win32.zip loaded on my machine.
Unable to create this part due to an internal error. Reason for the
failure: The Class File Viewer cannot handle the given input.
org.eclipse.core.runtime.CoreException: The Class File Viewer cannot
org.eclipse.jdt.internal.ui.javaeditor.ClassFileEditor.doSet Input(ClassFileEditor.java:612)
org.eclipse.ui.texteditor.AbstractTextEditor$16.run(Abstract TextEditor.java:2360)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
Previous Topic:get IProject instance from current working resources
Next Topic:FTP support
Current Time: Fri Jul 25 22:04:38 EDT 2025
Powered by FUDForum. Page generated in 0.31361 seconds
