Home » Language IDEs » C / C++ IDE (CDT) » Using templates in CDT/Linux/g++
Using templates in CDT/Linux/g++ [message #121687] Sun, 26 September 2004 16:57 Go to next message
Originally posted by: hma5.nospam.edu
This may be more of a g++ issue, but can anyone give me tips for working
with code that has C++ templates?
CDT in Linux/GTK uses G++ by default so templates defined in
"Box.h/Box.cpp" and used in "MyApp.cpp" gives "undefined reference to
Box<int>..." errors. (Sample code below)
Is there a coding change or a flag I can set in Eclipse on the compiler
to make this work?
Thanks!
Horus
Box.h
template<typename Type>
class Box{
private:
int n;
Type * _value;
public:
Box();
void setValue(Type * );
Type* getValue();
Box.cpp
#include "Box.h"
Box<Type>::Box()
void Box<Type>::setValue(Type * v)
_value = v;
Type * Box<Type>::getValue()
return _value;
MyApp.cpp
#include <iostream>
#include "Box.h"
#include <string>
using std::cout;
using std::endl;
using std::string;
int main()
Box<int> * b;
b = new Box<int>();
int * val = new int(3);
b->setValue(val);
cout << "The value in box is " << *(b->getValue()) << endl;
return 0;
Re: Using templates in CDT/Linux/g++ [message #121703 is a reply to message #121687] Sun, 26 September 2004 21:03 Go to previous message
http://babbage.cs.qc.edu/STL_Docs/templates.htm#T3
Implementing class template member functions
Implementing template member functions is somewhat different compared to
the regular class member functions. The declarations and definitions of
the class template member functions should all be in the same header file.
> to make this work?
> Thanks!
> Horus
> Box.h
> class Box{
> private:
> int n;
> Type * _value;
> public:
> Box();
> Type* getValue();
> Box.cpp
> #include "Box.h"
> Box<Type>::Box()
> _value = v;
> return _value;
> MyApp.cpp
> #include <iostream>
> #include "Box.h"
> #include <string>
> using std::cout;
> using std::endl;
> using std::string;
> int main()
> Box<int> * b;
> b = new Box<int>();
> b->setValue(val);
> return 0;
Previous Topic:C++ Properties pages
Next Topic:Indexing problems
Current Time: Tue Jul 22 19:50:37 EDT 2025
Powered by FUDForum. Page generated in 0.03901 seconds
