Home » Eclipse Projects » GEF » Determine connection anchor status
Determine connection anchor status [message #11131] Mon, 24 June 2002 04:50 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
How can I determine if a connection anchor is used by a connection or if it
is free?
I searched ConnectionEditPart and AbstractConnectionAnchor for suitable
methods to determen either the ConnectionAnchor used by a ConnectionEditPart
or the ConnectionEditPart connected an anchor. Maybe I'm blind but I
couldn't a suitable method for that.
I need to determine the connection status to avoid/forbid more than one
connection to the same anchor.
Cu, Gunnar
Re: Determine connection anchor status [message #11152 is a reply to message #11131] Mon, 24 June 2002 11:56 Go to previous messageGo to next message
Originally posted by: none.ibm.com
That is a model problem. You shouldn't be forbidding an interaction based
on the state of the figure, but instead on the state of the model.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:af6l02$voa$1@rogue.oti.com...
> Hi!
it
> is free?
ConnectionEditPart
> Cu, Gunnar
Re: Determine connection anchor status [message #11157 is a reply to message #11152] Tue, 25 June 2002 02:41 Go to previous message
"Randy Hudson" <none@ibm.com> schrieb im Newsbeitrag
news:af7mrl$kon$1@rogue.oti.com...
Aha, thanks.
Cu, Gunnar
Previous Topic:Using GEF Outside of Eclipse?
Next Topic:first connection
Current Time: Wed Jul 09 14:13:47 EDT 2025
Powered by FUDForum. Page generated in 0.05700 seconds
