Home » Eclipse Projects » Eclipse Platform » classpath to properties files - nested libraries
classpath to properties files - nested libraries [message #121628] Tue, 02 September 2003 23:08 Go to next message
I have .properies files in 2 directories - config/ and config/i18n. In the
plugin I am developing, I need to add these 2 directories to the list of
run-time libraries so that they will be in the plugin classpath and the
properties files will be found. The problem is that I get a Error message
"cannot nest config/i18n inside of config/" when I try adding config/i18n
after adding config/
Is there any way to get around this?
Vijay
Re: classpath to properties files - nested libraries [message #148423 is a reply to message #121628] Thu, 23 October 2003 09:53 Go to previous message
Originally posted by: prasarita.netscape.net
I've encountered this same problem and would be interested to see a
reply. It may be the case that it is necessary to add only (in your
case) the config directory. Do you get a MissingResourceException on
the config/i18n directory if only the config directory is added?
> Thanks
> Vijay
Previous Topic:Launching "Virtual" editors from a view
Next Topic:Create new project problems
Current Time: Sat Jul 19 03:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.02545 seconds
