Home » Modeling » GMF (Graphical Modeling Framework) » Link Constraint with oclIsKindOf
Link Constraint with oclIsKindOf [message #121619] Wed, 25 April 2007 03:55 Go to next message
I have two Metamodels: Core and Entity (Entity knows Core). Core defines
something like ModelElement and Dependency. In the Editor I created a
LinkMapping to have Dependencies between entity::Entity and
entity::EntityConstants. Of cource, the the normal behavior is that one
can create Dependencies between all ModelElements and this is not what I
want. I want to restrict the Dependency creation to Entity ->
EntityConstants.
I tried to define link constraints like:
self.oclIsKindOf(EntityConstants)
self.oclIsKindOf(Entity)
This fails because Entity/EntityConstants seem to be unknown:
Invalid expression body 'self.oclIsKindOf(Entity)
'. Cause: Invalid expression body 'self.oclIsKindOf(Entity)
'. Cause: ERROR in (variableExpCS): (Unrecognized variable: (Entity))
Can anyone give me hint how to proceed.
Mathias
Re: Link Constraint with oclIsKindOf [message #121686 is a reply to message #121619] Wed, 25 April 2007 05:39 Go to previous messageGo to next message
Hello Mathias,
Try using entity::EntityConstants as a parameter of oclIsKindOf.
Alex Shatalin
Re: Link Constraint with oclIsKindOf [message #125057 is a reply to message #121686] Thu, 10 May 2007 03:39 Go to previous messageGo to next message
Hello Alex,
I tried (in several variations: ::, : , fqn ...), but it does not work.
Mathias
Alex Shatalin schrieb:
> Hello Mathias,
> Alex Shatalin
Re: Link Constraint with oclIsKindOf [message #125410 is a reply to message #125057] Thu, 10 May 2007 08:12 Go to previous messageGo to next message
Hi Mathias,
Use both type names as qualified, the way Alex has suggested.
As you use two metamodels, it is unclear which package was taken
as the default one for resolving un-qualified names.
If you have tried so already, could you please post a simple test models
that we could reproduce this?
/Radek
On Thu, 10 May 2007 09:39:41 +0200, Mathias Freier
<mathias.freier@gentleware.com> wrote:
> Hello Alex,
> Mathias
>> Hello Mathias,
>> Alex Shatalin
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Link Constraint with oclIsKindOf [message #129205 is a reply to message #125410] Thu, 24 May 2007 06:33 Go to previous messageGo to next message
Originally posted by: bhatia1984.yahoo.com
hiiiii
I am also facing the same prob
I hv two metamodels Tde & UseCase
All the elements in UseCase extends from DiagramElement which i hv defined
in Tde & also the diagram of usecase extends from class which i hv define
in Tde.
By the way UseCase is usecase editor & Tde is statemachine editor.
now when i define
self.ocliskindof(Actor) in usecase it gives error.
but when i define
self.ocliskindof(StartState) in Tde it works fine.
i tried to define
self.ocliskindof(Actor::DiagramElement) but still it gives error.
what i want is that i dnt want any incoming transition on actor
Varun Bhatia
Re: Link Constraint with oclIsKindOf [message #129752 is a reply to message #129205] Fri, 25 May 2007 01:17 Go to previous messageGo to next message
hiii
plz reply to my above ques.
thanks
varun Bhatia
Re: Link Constraint with oclIsKindOf [message #130307 is a reply to message #129752] Fri, 25 May 2007 08:17 Go to previous messageGo to next message
hiiiii
is there any example on net where constraints are defined in java
thanks
Varun Bhatia
Re: Link Constraint with oclIsKindOf [message #130540 is a reply to message #130307] Mon, 28 May 2007 02:50 Go to previous messageGo to next message
Hi Varun,
Have a look at http://wiki.eclipse.org/index.php/GMF_Constraints#Java
/Radek
On Fri, 25 May 2007 14:17:35 +0200, varun bhatia <bhatia1984@yahoo.com>
wrote:
> hiiiii
> thanks
> Varun Bhatia
Re: Link Constraint with oclIsKindOf [message #130553 is a reply to message #129205] Mon, 28 May 2007 03:03 Go to previous message
Hi Varun,
It is not easy to see what erros you report here,
as you use 'ocliskindof' instead of 'oclIsKindOf'.
Also, 'Actor' used as type first and then as a package
in 'Actor::DiagramElement' indicates there might be other
causes of errors.
/Radek
On Thu, 24 May 2007 12:33:00 +0200, varun <bhatia1984@yahoo.com> wrote:
> hiiiii
> defined in Tde & also the diagram of usecase extends from class which i
> hv define in Tde.
> now when i define
> but when i define self.ocliskindof(StartState) in Tde it works fine.
> i tried to define self.ocliskindof(Actor::DiagramElement) but still it
> gives error.
> Thanks
> Varun Bhatia
Previous Topic:How can I render a figure like Rational Rose style?
Next Topic:diagram refresh on delete connection
Current Time: Mon Jul 14 00:18:12 EDT 2025
Powered by FUDForum. Page generated in 0.04588 seconds
