Home » Modeling » BPEL Designer » The BPLE cannot be published to the AvtiveBPEL 3.0 using AER Plugin
The BPLE cannot be published to the AvtiveBPEL 3.0 using AER Plugin [message #11130] Tue, 09 September 2008 22:52
Originally posted by: maple19862001.163.com
Hi,all
I've downloaded the Europa released version activeBpel runtime plugin,
unzip it on the Eclipse plugins folder,
Resuming, once created the server and added the bpel project (in my case
it's called loan.bpel),
i right-clicked on ActiveBPEL 3.0 Server, then "publish". But something
is wrong.Problem occurred:
Reading XPath Function Registry...
Reason:
java.io.FileNotFoundException: /functions/function.xml
Seeing the errorlog:
!ENTRY org.eclipse.bpel.validator 1 0 2008-09-10 09:55:31.063
!MESSAGE Validator Startup 328ms
!SESSION 2008-09-10 10:19:02.017
eclipse.buildId=M20070921-1145
java.version=1.6.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.configurator 2008-09-10 10:19:22.126
!MESSAGE Could not install bundle
plugins/net.sourceforge.lpg.lpgjavaruntime.source_1.1.0.v200 706111738.jar
Bundle "net.sourceforge.lpg.lpgjavaruntime.source" version
"1.1.0.v200706111738" has already been installed from:
update@plugins /net.sourceforge.lpg.lpgjavaruntime.source_1.1.0.v2007061117 38/
!ENTRY org.eclipse.ui.workbench 2 0 2008-09-10 10:20:33.392
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-09-10 10:20:33.392
!MESSAGE Conflict for
'AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse. ui.cheatsheets.actions.CheatSheetHelpMenuAction':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.ui.cheatsh eets.actionSet/org.eclipse.ui.cheatsheets.actions.CheatSheet HelpMenuAction,
handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.cheat sheets.CheatSheetExtensionFactory:helpMenuAction),
expression=AndExpression(ActionSetExpression(org.eclipse.ui. cheatsheets.actionSet,org.eclipse.ui.internal.WorkbenchWindow@8ef465),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@8ef465)),sourcePriority=16640)
handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.inter nal.cheatsheets.actions.CheatSheetHelpMenuAction),
!ENTRY org.eclipse.wst.server.core 4 0 2008-09-10 10:31:46.345
!MESSAGE Error calling delegate canModifyModules() ActiveBPEL 3.0
!STACK 0
org.eclipse.wst.server.core.internal.facets.FacetUtil.verify Facets(FacetUtil.java:127)
at org.eclipse.jst.server.core.FacetUtil.verifyFacets(FacetUtil .java:73)
org.eclipse.jst.server.generic.core.internal.GenericServer.c anModifyModules(GenericServer.java:61)
org.eclipse.wst.server.core.internal.Server.canModifyModules (Server.java:2178)
org.eclipse.wst.server.ui.internal.view.servers.ModuleSloshA ction.perform(ModuleSloshAction.java:76)
org.eclipse.wst.server.ui.internal.view.servers.AbstractServ erAction.run(AbstractServerAction.java:55)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
!ENTRY org.eclipse.wst.server.core 4 0 2008-09-10 10:31:47.173
!MESSAGE Error calling delegate getParentModules() ServerWorkingCopy
08-9-9_涓
Previous Topic:Usind Designer with Ganymede
Next Topic:WS-BPEL Extension for People
Current Time: Sun Jul 27 01:23:30 EDT 2025
Powered by FUDForum. Page generated in 0.03750 seconds
