Home » Language IDEs » C / C++ IDE (CDT) » Compiling for a remote host
Compiling for a remote host [message #121463] Thu, 23 September 2004 06:36 Go to next message
I add the same problem.
I solved it by changing the default command that appears in Properties
dialog ->C/C++ Make Project option->Make Builder tab.
In the Build command panel uncheck the Use default option and in the Build
command field add your command (I created an external tool for compilation
and ran it from there, but you can run a remote command like : rsh
hostname make)
Re: Compiling for a remote host [message #121486 is a reply to message #121463] Thu, 23 September 2004 11:43 Go to previous messageGo to next message
Originally posted by: ravi_kohli2000.yahoo.com
I've set up "C/C++ Make Project" to "ssh remotehost /path/make". Looks like
it
successfully runs the "make" command remotely now since I get a resp
on the console. I've not completed the remote build as yet. I get an error
"make: Fatal error: Don't know how to make target `clean'
My makefile maybe wrong(?). Is it because I need to specify "remote"
commands
e.g. for "clean" (below that uses "rm", should be ssh or (??) ? You
mentioned a tool
for compiling. I'm not sure if you mean you replace the "make" command in
the
"C/C++ Make Project" option.
I'm using a simple "Makefile" in the Eclipse project that looks like:
%.o: %.cpp
$(CC) $(CFLAGS) -c $<
CC = g++
LD = ld
CFLAGS = $(INCLUDE) $(DEFINES) $(DEBUG)
DEBUG = -g -Wall
DEFINES = -D"somedef"
INCLUDE = -I. -I"someinc"
LDFLAGS = -L"someflags"
LIBS = -l"somelibs"
all: test
test: main.o pgm.o
$(CC) $(LDFLAGS) -o test main.o pgm.o $(LIBS)
clean:
rm -f test main.o pgm.o
Can you explain what's wrong with the way I'm remote compiling from
my PC ?
Thanks in advance.
"Guy" <guy.Milman@comverse.com> wrote in message
news:ciu8vk$e43$1@eclipse.org...
> hostname make)
> hostname make)
Re: Compiling for a remote host [message #121623 is a reply to message #121486] Sat, 25 September 2004 22:15 Go to previous messageGo to next message
You need to change into your remote project directory and do the make
from there. Sure the tools should be the one available to the remote
machine.
Though,
ssh <remotehost> cd <projectdir> && make
Since the makefile is executed by the remote make, 'rm -rf' is
sufficient as long as it is in the remote's path.
Best is to do the macro expansion thing
RM = rm -rf
clean:
$(RM) $(OBJECTS) $(TARGET)
> it
> commands
> mentioned a tool
> the
> %.o: %.cpp
> CC = g++
> LD = ld
> DEBUG = -g -Wall
> LIBS = -l"somelibs"
> all: test
> test: main.o pgm.o
> clean:
> my PC ?
> Thanks in advance.
>>Hi,
>>hostname make)
>>Hi,
>>hostname make)
Re: Compiling for a remote host [message #121996 is a reply to message #121623] Tue, 28 September 2004 14:04 Go to previous message
Thanks alot ! I'm able to build code remotely using ssh, etc. now.
I am still usure how am I supposed to use Eclipse features if I do it like
this.
I have access to a CVS server for the .C files. If I "cd" to the source code
on the remote machine like this (via a Make commandline in Eclipse), Eclipse
is
not using the files I have just retrieved from CVS (in the C/C++ project).
It's using files
(that I also saved on a remote server dir) to build. I had wanted to use the
files in the the
Navigator to build,etc so that I can use the editor and run the debugger on
the PC. Can
you pls clarify that setup too ?
Thanks in advance.
"kesselhaus" <kesselhaus@gmx.net> wrote in message
news:cj58dg$ms1$1@eclipse.org...
> machine.
> Though,
> RM = rm -rf
> clean:
like
> > it
error
> > commands
> > mentioned a tool
in
> > the
> > %.o: %.cpp
> > CC = g++
> > LD = ld
> > DEBUG = -g -Wall
> > LIBS = -l"somelibs"
> > all: test
> > test: main.o pgm.o
> > clean:
> > my PC ?
> > Thanks in advance.
> >>Hi,
Build
compilation
> >>hostname make)
> >>Hi,
Build
compilation
> >>hostname make)
Previous Topic:C function start and end Line using the eclipse CDT Parser
Next Topic:Program Does Not Exist
Current Time: Tue Dec 02 13:54:29 EST 2025
Powered by FUDForum. Page generated in 0.03649 seconds
