Problem with fill style in Properties View (Apperance) if background color defined in gmfgraph [message #121361] |
Mon, 23 April 2007 11:53 |
Originally posted by: bsu.bergauer.ch
I have defined three different rectangle figures in the gmfgraph figure
gallery. In order to visually distinguish them I assigned different
background color child elements to each of the rectangle figures.
When I add a node to the diagram using one of those rectangle figures, the
background color is correct, as assigned in gmfgen. However, when I select
one of those nodes on the diagram area with the mouse, the fill color in the
properties view (Apperarance tab) for this node is not showing the
background color of the node but white (the default set in the class
FillStyleImpl). If I try to choose another fill color in the properties
view the background color of the node is not changed in the diagram. I
tested with properties that I haven't "overridden" in the gmfgen, i.e. font
type, size and border color etc, and there is an immediate change for the
selected node in the diagram.
Questions:
1) What do I have to do in order to have the same fill style in the
properties view for an node with the same default background color as
assigned in the gmfgen?
2) How can I get the selected fill color in the properties view to be
applied to the node in the diagram?
Bj
FUDForum. Page generated in 0.02795 seconds
