Supporting for more than one kind of Connections [message #11096] |
Sat, 22 June 2002 03:19  |
I want to support 2 kinds of connection, and each kind of connection has
its own kind of EditPart, and I add the 2 connection tools to the palette
with the following code
tool = new DefaultPaletteToolEntry(
new ConnectionTool(),
"connection1",
"connection1",
Image16,
entries.add(tool);
"connection2",
"connection2",
Image16,
entries.add(tool);
However, in the NodeEditPolicy.getConnectionCreateCommand(request) method,
request.getNewObject and request.getNewObjectType all returns null, so
that I cannot distinguish which kind of connection to create
The current solution is to keep reference of the two new ConnectionTool in
the above code as connection1Tool and connection2Tool, and then at the
NodeEditPolicy.getConnectionCreateCommand(request) method, I can determine
which kind of connection to create by testing which tool is the current
active tool get from
getHost().getRoot().getViewer().getEditDomain().getActiveToo l()
Obvious this is not a good solution because of the more tight coupling
degree between editpolicies and palettes. So I want to know why
request.getNewObject and request.getNewObjectType will be null? Is it a
bug? Or is there any other way of solving this problem
Re: Supporting for more than one kind of Connections [message #11101 is a reply to message #11096] |
Sat, 22 June 2002 16:53  |
Originally posted by: none.ibm.com
If you set the Factory on the ConnectionCreationTool, it should provide the
new Type and instance information to the request.
Someone at IBM requested this about 6 months ago so I believe it should
work.
"Jun Zhu" <zhujun@cn.ibm.com> wrote in message
news:af18ep$8tc$1@rogue.oti.com...
> "connection1",
> "connection1",
> Image16,
> Image32
> entries.add(tool);
> "connection2",
> "connection2",
> Image16,
> Image32
> entries.add(tool);
FUDForum. Page generated in 0.09105 seconds
