Home » Archived » Visual Editor (VE) » Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT
Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121265] Sat, 01 April 2006 06:05 Go to next message
Originally posted by: chaohongliu.vip.sina.com
I want to develop SWT program with Borland Architect 2006 which inner
Eclipse version is 3.1, So I download the Eclipse 3.1,VE1.1.01 and other
required.
I have successfully installed the VE1.1.01 and Eclipse 3.1. I can programm
with VE in Borland Architect 2006, It really work with swing.
but when I use "Viusal Class" wizardpage to create a new class extends SWT
Composite,it can not show the appearance of the control and show
"java.lang.NoClassDefFoundError".
Regards for any suggestion.
Frank Liu
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121379 is a reply to message #121265] Mon, 03 April 2006 09:58 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Do you have the Eclipse SDK installed? The VE SWT component needs to
have PDE also and if you use just Eclipse Runtime and JDT you won't get PDE.
Attach the .log file please. That will tell us what class is missing.
Rich Kulp
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121387 is a reply to message #121379] Mon, 03 April 2006 20:42 Go to previous messageGo to next message
Thanks, the following are the error messages.
ERROR DETAIL:
Error 2006-04-04 08:37:00.442 Failed to execute runnable
(java.lang.NullPointerException)
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:90)
org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
SESSION DATA:
eclipse.buildId=I20050627-1435
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.borland.tg.primary.architect.feature.tec
Command-line arguments: -os win32 -ws win32 -arch x86 -product
com.borland.tg.primary.architect.feature.tec -data E:\Dragon
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121395 is a reply to message #121387] Mon, 03 April 2006 20:48 Go to previous messageGo to next message
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedSing le(XMLSaveImpl.java:1988)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1215)
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1358)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:923)
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Warning 2006-04-04 08:36:43.468 Exception thrown.
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.loadClass(ExpressionProcesserController.java:134)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:379)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:989)
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:311)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1992)
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121411 is a reply to message #121395] Tue, 04 April 2006 10:14 Go to previous messageGo to next message
Some of the errors are due to a bad cache problem.
To clear the cache do:
1) Open a VE, then close it and all other VE's.
2) Do a Project->Clean...->Clean All... Wait for build to finish.
3) Try opening the VE again.
Rich Kulp
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121433 is a reply to message #121411] Wed, 05 April 2006 08:15 Go to previous messageGo to next message
Thanks very much for your replay!
I have tried by as your direction,but it still doesn't work.
there is the error log messgae:
java.lang.NoClassDefFoundError: org.eclipse.swt.widgets.Widget
at java.lang.Class.forName(Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:140)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:391)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:202)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:368)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:267)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:769)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:474)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:461)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEvents(BeaninfoClassAdapter.java:1125)
org.eclipse.jem.java.impl.JavaClassImpl.getEvents(JavaClassI mpl.java:1314)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allEvents(BeaninfoClassAdapter.java:2169)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllEvents(BeaninfoClassAdapter.java:1133)
org.eclipse.jem.java.impl.JavaClassImpl.getAllEvents(JavaCla ssImpl.java:1336)
org.eclipse.ve.internal.java.codegen.java.EventsParser.getAd dSignitures(EventsParser.java:64)
org.eclipse.ve.internal.java.codegen.java.EventsParser.analy ze(EventsParser.java:97)
org.eclipse.ve.internal.java.codegen.java.EventsParser.addEv ents(EventsParser.java:133)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.analyzeEvents(JavaBeanModelBuilder.java:346)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:437)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:832)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:914)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:575)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1881)
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121440 is a reply to message #121411] Wed, 05 April 2006 08:26 Go to previous messageGo to next message
Thanks very much for your reply.
I have tried as your direction,but it still doesn't work.
There is the message of the error log file:
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121461 is a reply to message #121440] Wed, 05 April 2006 10:54 Go to previous message
Could you please append your .classpath file for the project? This is
saying it can't find SWT.
Rich Kulp
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612465 is a reply to message #121265] Mon, 03 April 2006 09:58 Go to previous message
Rich Kulp
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612468 is a reply to message #121379] Mon, 03 April 2006 20:42 Go to previous message
ERROR DETAIL:
... 18 more
SESSION DATA:
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612471 is a reply to message #121387] Mon, 03 April 2006 20:48 Go to previous message
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612477 is a reply to message #121395] Tue, 04 April 2006 10:14 Go to previous message
Rich Kulp
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612486 is a reply to message #121411] Wed, 05 April 2006 08:15 Go to previous message
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612487 is a reply to message #121411] Wed, 05 April 2006 08:26 Go to previous message
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612493 is a reply to message #121440] Wed, 05 April 2006 10:54 Go to previous message
Rich Kulp
Previous Topic:Problem of Multiple Invocation
Next Topic:Problem of Multiple Invocation
Current Time: Fri Jul 18 00:28:21 EDT 2025
Powered by FUDForum. Page generated in 0.18203 seconds
