Home » Language IDEs » ServerTools (WTP) » RDB - Adding a new database & suppression of schema object lookup
RDB - Adding a new database & suppression of schema object lookup [message #121242] Fri, 15 July 2005 15:20
Originally posted by: nospam.eclipse.org
Eclipse version: 3.1 Final
Webtools version: 0.7 RC1
OS: Windows XP Professional
I'm attempting to setup access for DB2 UDB 7.1. RDB had drivers for DB2
UDB 7.1 in a previous release, M2, so I figured it would be possible to
copy them over. I attempted modifying
%ECLIPSE_DIRECTORY%\plugins\org.eclipse.wst.rdb.dbdefinition .db2.luw_0.7.0\plugin.properties
%ECLIPSE_DIRECTORY%\plugins\org.eclipse.wst.rdb.dbdefinition .db2.luw_0.7.0\plugin.xml
to add the DB2 7.0 entries, & copied the file "DB2 UDB_7.0.xmi" from the
old milestone release of WTP to the new most recent version of WTP (0.7
RC1).
I start Eclipse, and the newly added DB2 UDB 7.0 database configuration
option did not display when I attempted to created a "New Connection..."
via the Database Explorer view. I attempted looking around for a "refresh
plug in option" but hadn't found any, nor do I know if it was needed
anyways. Thus, RDB question #1: how do I make a custom database
configuration option display?
Question #2: I faintly remember there being a helpful document or archived
message on the eclipse site bearing information on how to supress looking
up objects in a SQL qualified schema. In other words, if I type "SCEHMA."
in the SQL editor, as soon as I end the period, RDB will look up all
potential DB schema objects for that schema. I'd like to suppress that,
but I can no longer find any reference to this.
Previous Topic:Can't create EJB project
Next Topic:Web app libs
Current Time: Sun Aug 31 15:55:06 EDT 2025
Powered by FUDForum. Page generated in 0.03443 seconds
