novice [message #121232] |
Fri, 31 March 2006 12:53  |
Originally posted by: adoneNOSPAMborione.cantv.net
Hi all
I would like to ask if there is some tutorial on VE for me to start do
some coding.
I tried to open the examples "SimpleTextEditor" (file->new->example) but
the example only shows a skeleton class with almost no code.
A comment says "An example which shows off a functional simple text
editor. Includes a variety of events." but I can't see anything useful
So, how do I learn more?
Are there online courses?
Adone
Re: novice [message #121249 is a reply to message #121232] |
Fri, 31 March 2006 13:21   |
Hmmm, there may be something wrong with your installation if you're not
getting the contents of the Examples. Check the error log by going to
Window->Show View->Other->PDE Runtime->Error log
Below is the code I get when I try the SimpleTextEditor example:
import javax.swing.JFrame;
import java.io.*;
import javax.swing.JFileChooser;
import javax.swing.JOptionPane;
* An example which shows off a functional simple text editor.
public class SimpleTextEditor extends JFrame {
private javax.swing.JPanel jContentPane = null;
private javax.swing.JPanel jPanel = null;
private javax.swing.JButton jButton = null;
private javax.swing.JButton jButton1 = null;
private javax.swing.JButton jButton2 = null;
private javax.swing.JScrollPane jScrollPane = null;
private javax.swing.JTextArea jTextArea = null;
private javax.swing.JFileChooser jFileChooser = null; //
@jve:visual-info decl-index=0 visual-constraint="582,36"
private boolean hasChanged = false;
private static final String title = "Simple Text Editor";
* This method initializes
public SimpleTextEditor() {
super();
initialize();
SimpleTextEditor ste = new SimpleTextEditor();
ste.show();
* This method initializes jContentPane
* @return javax.swing.JPanel
private javax.swing.JPanel getJContentPane() {
if (jContentPane == null) {
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(new java.awt.BorderLayout());
jContentPane.add(getJPanel(), java.awt.BorderLayout.SOUTH);
jContentPane.add(getJScrollPane(), java.awt.BorderLayout.CENTER);
jContentPane.setBorder(javax.swing.BorderFactory.createEmpty Border(
5, 5, 5, 5));
return jContentPane;
* This method initializes this
* @return void
private void initialize() {
this.setContentPane(getJContentPane());
this.setSize(480, 284);
this.setTitle(title);
this
..setDefaultCloseOperation(javax.swing.WindowConstants.DO_NO THING_ON_CLOSE);
this.addWindowListener(new java.awt.event.WindowAdapter() {
public void windowClosing(java.awt.event.WindowEvent e) {
doExit();
* This method initializes jPanel
private javax.swing.JPanel getJPanel() {
if (jPanel == null) {
jPanel = new javax.swing.JPanel();
jPanel.add(getJButton(), null);
jPanel.add(getJButton1(), null);
jPanel.add(getJButton2(), null);
return jPanel;
* This method initializes jButton
* @return javax.swing.JButton
private javax.swing.JButton getJButton() {
if (jButton == null) {
jButton = new javax.swing.JButton();
jButton.setText("Load File");
jButton.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent e) {
loadFile();
return jButton;
* This method initializes jButton1
private javax.swing.JButton getJButton1() {
if (jButton1 == null) {
jButton1 = new javax.swing.JButton();
jButton1.setText("Save File");
jButton1.addActionListener(new java.awt.event.ActionListener() {
saveFile();
return jButton1;
* This method initializes jButton2
private javax.swing.JButton getJButton2() {
if (jButton2 == null) {
jButton2 = new javax.swing.JButton();
jButton2.setText("Exit");
jButton2.addActionListener(new java.awt.event.ActionListener() {
doExit();
return jButton2;
* This method initializes jScrollPane
* @return javax.swing.JScrollPane
private javax.swing.JScrollPane getJScrollPane() {
if (jScrollPane == null) {
jScrollPane = new javax.swing.JScrollPane();
jScrollPane.setViewportView(getJTextArea());
return jScrollPane;
* This method initializes jTextArea
* @return javax.swing.JTextArea
private javax.swing.JTextArea getJTextArea() {
if (jTextArea == null) {
jTextArea = new javax.swing.JTextArea();
jTextArea.addKeyListener(new java.awt.event.KeyAdapter() {
public void keyTyped(java.awt.event.KeyEvent e) {
if (!hasChanged) {
setTitle(title + " *");
hasChanged = true;
return jTextArea;
* This method initializes jFileChooser
* @return javax.swing.JFileChooser
private javax.swing.JFileChooser getJFileChooser() {
if (jFileChooser == null) {
jFileChooser = new javax.swing.JFileChooser();
jFileChooser.setMultiSelectionEnabled(false);
return jFileChooser;
private void loadFile() {
int state = getJFileChooser().showOpenDialog(this);
if (state == JFileChooser.APPROVE_OPTION) {
File f = getJFileChooser().getSelectedFile();
try {
BufferedReader br = new BufferedReader(new FileReader(f));
getJTextArea().read(br, null);
br.close();
setTitle(title);
hasChanged = false;
} catch (FileNotFoundException e1) {
e1.printStackTrace();
} catch (IOException e1) {
private void saveFile() {
int state = getJFileChooser().showSaveDialog(this);
try {
BufferedWriter bw = new BufferedWriter(new FileWriter(f));
getJTextArea().write(bw);
bw.close();
setTitle(title);
hasChanged = false;
private void doExit() {
if (hasChanged) {
int state = JOptionPane.showConfirmDialog(this,
"File has been changed. Save before exit?");
if (state == JOptionPane.YES_OPTION) {
saveFile();
} else if (state == JOptionPane.CANCEL_OPTION) {
return;
System.exit(0);
} // @jve:visual-info decl-index=0 visual-constraint="20,27"
Re: novice [message #121256 is a reply to message #121249] |
Fri, 31 March 2006 13:31   |
There is the following messages but I do not think are related to the
examples
eclipse.buildId=I20060223-1656
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_VE
Command-line arguments: -os win32 -ws win32 -arch x86
Error
2006-03-29 13:08:52.593
Unable to access site:
"http://http://update.eclipse.org/tools/ve/updates/1.0/" [http]
java.net.UnknownHostException: http
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection$6.run(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getChainedExcept ion(Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(U nknown
Source)
org.eclipse.update.internal.core.connection.ConnectionThread Manager$StreamRunnable.run(ConnectionThreadManager.java:97)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.UnknownHostException: http
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient (Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unk nown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
org.eclipse.update.internal.core.connection.HttpResponse.get StatusCode(HttpResponse.java:183)
org.eclipse.update.internal.core.UpdateManagerUtils.checkCon nectionResult(UpdateManagerUtils.java:553)
org.eclipse.update.internal.core.SiteURLFactory.createSite(S iteURLFactory.java:74)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:332)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:324)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:296)
org.eclipse.update.internal.core.InternalSiteManager.attempt CreateSite(InternalSiteManager.java:220)
org.eclipse.update.internal.core.InternalSiteManager.getSite (InternalSiteManager.java:161)
at org.eclipse.update.core.SiteManager.getSite(SiteManager.java :78)
org.eclipse.update.search.UpdateSearchRequest.searchOneSite( UpdateSearchRequest.java:345)
org.eclipse.update.search.UpdateSearchRequest.performSearch( UpdateSearchRequest.java:273)
at org.eclipse.update.ui.UpdateJob.runSearchForNew(UpdateJob.ja va:180)
at org.eclipse.update.ui.UpdateJob.run(UpdateJob.java:168)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
> import java.io.*;
> super();
> initialize();
> public static void main(String[] args) {
> ste.show();
> 5, 5, 5, 5));
> * @return void
> this
> doExit();
> return jPanel;
> loadFile();
> return jButton;
> saveFile();
> return jButton1;
> doExit();
> return jButton2;
> return jScrollPane;
> if (!hasChanged) {
> hasChanged = true;
> return jTextArea;
> try {
> br.close();
> setTitle(title);
> hasChanged = false;
> try {
> bw.close();
> setTitle(title);
> hasChanged = false;
> if (hasChanged) {
> saveFile();
> return;
> System.exit(0);
Re: novice [message #121337 is a reply to message #121289] |
Sat, 01 April 2006 20:33  |
I got it!
At last I understood the philosophy of eclipse and its plugins!
I was able to create different installs of different versions. I
understood also what release and stream mean.
I understood that I cannot use update manager unless I am using a release
version.
EUREKA!!
I MADE IT!!!
Re: novice [message #612412 is a reply to message #121232] |
import java.io.*;
super();
initialize();
ste.show();
5, 5, 5, 5));
* @return void
this
doExit();
return jPanel;
loadFile();
return jButton;
saveFile();
return jButton1;
doExit();
return jButton2;
return jScrollPane;
if (!hasChanged) {
hasChanged = true;
return jTextArea;
try {
br.close();
setTitle(title);
hasChanged = false;
try {
bw.close();
setTitle(title);
hasChanged = false;
if (hasChanged) {
saveFile();
return;
System.exit(0);
Re: novice [message #612415 is a reply to message #121249] |
examples
Error
Source)
Source)
Source)
Source)
Source)
> import java.io.*;
> super();
> initialize();
> ste.show();
> 5, 5, 5, 5));
> * @return void
> this
> doExit();
> return jPanel;
> loadFile();
> return jButton;
> saveFile();
> return jButton1;
> doExit();
> return jButton2;
> return jScrollPane;
> if (!hasChanged) {
> hasChanged = true;
> return jTextArea;
> try {
> br.close();
> setTitle(title);
> hasChanged = false;
> try {
> bw.close();
> setTitle(title);
> hasChanged = false;
> if (hasChanged) {
> saveFile();
> return;
> System.exit(0);
Re: novice [message #612431 is a reply to message #121281] |
Sat, 01 April 2006 12:44  |
Thanks Fred but I have done it and the update manager does not report any
update available.
How do I reinstall the examples?
Fred Grott wrote:
> You need to take out that extra http:// in the update site url of the VE
project//
Re: novice [message #612448 is a reply to message #121289] |
I got it!
version.
EUREKA!!
I MADE IT!!!
FUDForum. Page generated in 0.05527 seconds
