Home » Archived » Visual Editor (VE) » Not able to create RCP View/Editor style - throws
Not able to create RCP View/Editor style - throws [message #121108] Wed, 29 March 2006 13:24 Go to next message
I am the first time user for visual editor, and I am not able to create
RCP/SWT visual class. It throws errors as listed below.
Note: I am able to create awt/swing visual class and also able to drag and
drop controls from the palette.
Please help me to proceed with RCP/SWT visual class.
My Machine is set up with following versions:
Eclipse build eclipse-SDK-3.2M5a:
EMF build 2.2.0M5:
GEF Build 3.2M5:
VE-SDK-1.2M2
Here is the log:
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.375
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.UnsatisfiedLinkError: swt-win32-3224 (Not found in
java.library.path)
at java.lang.ClassLoader.loadLibraryWithPath(ClassLoader.java:9 49)
at java.lang.ClassLoader.loadLibraryWithClassLoader(ClassLoader .java:918)
at java.lang.System.loadLibrary(System.java:451)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:161)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
at java.lang.Class.forNameImpl(Native Method)
at java.lang.Class.forName(Class.java:131)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:140)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
java.library.path)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:391)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:202)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:368)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:267)
org.eclipse.jem.internal.proxy.swt.DisplayManager$Constants. <init>(DisplayManager.java:305)
org.eclipse.jem.internal.proxy.swt.DisplayManager$Constants. getConstants(DisplayManager.java:272)
org.eclipse.jem.internal.proxy.swt.DisplayManager.getCurrent Display(DisplayManager.java:452)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.onUIThr ead(UIThreadOnlyProxyAdapter.java:119)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.instant iateAndInitialize(UIThreadOnlyProxyAdapter.java:125)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:328)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.initSetting(MemberContainerProxyAdapter.java:546)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.su bInitBeanProxy(CompositionProxyAdapter.java:315)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.initBeanProxy(MemberContainerProxyAdapter.java:565)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:2089)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.ve.java.core 2 0 2006-03-29 10:15:07.406
!MESSAGE Exception thrown.
!STACK 0
java.lang.NullPointerException: public static void
org.eclipse.ve.internal.jface.targetvm.JFaceColorRegistryIni tializer.init(java.util.Map,org.eclipse.ve.internal.swt.targ etvm.Environment)
org.eclipse.ve.internal.jface.targetvm.JFaceColorRegistryIni tializer.init(JFaceColorRegistryInitializer.java:34)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.pushMethodInvocation(ExpressionProcesser.java:2605)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:284)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:989)
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
org.eclipse.ve.internal.jface.JFaceConfigurationContributor$ 1.run(JFaceConfigurationContributor.java:44)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3264)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2910)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.468
!MESSAGE
+++ Warning +++: Wed Mar 29 10:15:07 PST 2006 Project
(Proj1)-Beaninfo:err>
Exception in thread "SWT UI Thread for VE for Env:
org.eclipse.ve.internal.swt.targetvm.win32.Environment@34083408"
java.library.path)
org.eclipse.ve.internal.swt.targetvm.Environment$3.run(Envir onment.java:112)
org.eclipse.ve.internal.swt.targetvm.win32.Environment@478a478a"
java.lang.NoClassDefFoundError: org.eclipse.swt.widgets.Display
at java.lang.J9VMInternals.initialize(J9VMInternals.java:127)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.515
!MESSAGE
!STACK 0
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:317)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:221)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:178)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:98)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:231)
org.eclipse.jem.internal.proxy.swt.JavaStandardSWTBeanConsta nts.getDisplayProxy(JavaStandardSWTBeanConstants.java:145)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.onUIThr ead(UIThreadOnlyProxyAdapter.java:120)
!ENTRY org.eclipse.ve.java.core 2 0 2006-03-29 10:15:07.562
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.609
!MESSAGE
!STACK 0
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.memberInitBeanProxy(MemberContainerProxyAdapter.java:621)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.initBeanProxy(MemberContainerProxyAdapter.java:570)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.625
!MESSAGE
+++ Warning +++: Wed Mar 29 10:15:07 PST 2006 Project (Proj1)-VM for
Proj1:err>
org.eclipse.ve.internal.swt.targetvm.win32.Environment@41264126"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@51ba51ba"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@54c454c4"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@42044204"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@445c445c"
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.656
!MESSAGE
!STACK 0
org.eclipse.ve.internal.java.core.BasicAllocationProcesser$P arseAllocation.visit(BasicAllocationProcesser.java:78)
org.eclipse.jem.internal.instantiation.impl.PTInstanceRefere nceImpl.accept0(PTInstanceReferenceImpl.java:165)
org.eclipse.jem.internal.instantiation.impl.PTExpressionImpl .childAccept0(PTExpressionImpl.java:126)
org.eclipse.jem.internal.instantiation.impl.PTExpressionImpl .accept(PTExpressionImpl.java:60)
org.eclipse.jem.internal.instantiation.base.ParseTreeAllocat ionInstantiationVisitor.visit(ParseTreeAllocationInstantiati onVisitor.java:335)
org.eclipse.jem.internal.instantiation.impl.PTClassInstanceC reationImpl.accept0(PTClassInstanceCreationImpl.java:224)
org.eclipse.jem.internal.instantiation.base.ParseTreeAllocat ionInstantiationVisitor.getProxy(ParseTreeAllocationInstanti ationVisitor.java:208)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAllocationProcesser.java:160)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAllocationProcesser.java:362)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateDroppedPart(BeanProxyAdapter.java:1264)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:1243)
org.eclipse.ve.internal.swt.WidgetProxyAdapter.primInstantia teBeanProxy(WidgetProxyAdapter.java:165)
org.eclipse.ve.internal.swt.ControlProxyAdapter.primInstanti ateBeanProxy(ControlProxyAdapter.java:148)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teAndInitialize(BeanProxyAdapter.java:387)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.primIns tantiateAndInitialize(UIThreadOnlyProxyAdapter.java:163)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.instant iateAndInitialize(UIThreadOnlyProxyAdapter.java:126)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.703
!MESSAGE
!STACK 0
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.applied List(UIThreadOnlyProxyAdapter.java:210)
org.eclipse.ve.internal.java.core.BeanProxyAdapter$5.isSet(B eanProxyAdapter.java:491)
org.eclipse.jem.internal.instantiation.base.JavaInstance.vis itSetFeatures(JavaInstance.java:70)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.applyAllS ettings(BeanProxyAdapter.java:485)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teAndInitialize(BeanProxyAdapter.java:463)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.734
!MESSAGE
!STACK 0
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.applied (UIThreadOnlyProxyAdapter.java:173)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.appliedLi st(BeanProxyAdapter.java:1146)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.primApp liedList(UIThreadOnlyProxyAdapter.java:237)
org.eclipse.ve.internal.swt.WidgetProxyAdapter.primAppliedLi st(WidgetProxyAdapter.java:222)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.applied List(UIThreadOnlyProxyAdapter.java:211)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.765
!MESSAGE
Proj1:err>
org.eclipse.ve.internal.swt.targetvm.win32.Environment@2ea02ea"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@16581658"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@35f035f0"
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.781
!MESSAGE
!STACK 0
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.memberInitBeanProxy(MemberContainerProxyAdapter.java:642)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.812
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.843
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.859
!MESSAGE
!STACK 0
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teSettingBean(BeanProxyAdapter.java:1011)
org.eclipse.ve.internal.swt.CompositeProxyAdapter.addControl (CompositeProxyAdapter.java:121)
org.eclipse.ve.internal.swt.CompositeProxyAdapter.applySetti ng(CompositeProxyAdapter.java:71)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.applied(B eanProxyAdapter.java:700)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.primApp lied(UIThreadOnlyProxyAdapter.java:200)
org.eclipse.ve.internal.swt.CompositeProxyAdapter.primApplie d(CompositeProxyAdapter.java:66)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.applied (UIThreadOnlyProxyAdapter.java:174)
!ENTRY org.eclipse.jem.proxy 2 0 2006-03-29 10:15:07.890
!MESSAGE
Proj1:err>
org.eclipse.ve.internal.swt.targetvm.win32.Environment@495e495e"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@d7e0d7e"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@27202720"
org.eclipse.ve.internal.swt.targetvm.win32.Environment@3aa23aa2"
!ENTRY org.eclipse.ve.java.core 2 0 2006-03-29 10:15:19.453
!STACK 0
Re: Not able to create RCP View/Editor style - throws [message #121140 is a reply to message #121108] Wed, 29 March 2006 13:38 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What was the process you used to create the RCP class?
Rich Kulp
Re: Not able to create RCP View/Editor style - throws [message #121156 is a reply to message #121140] Wed, 29 March 2006 14:13 Go to previous messageGo to next message
I created New Plug-In project with defaults:
Target platform:
Eclipse version 3.2 is cheked
an OSGi frame work unchecked.
I set yes to create rich client application and selected RCP Mail Template.
then I created New Java Visual class with RPC->View style and gets the
exception as I mentioned in earlier note.
Please let me know if you need more info.
Bob
Re: Not able to create RCP View/Editor style - throws [message #121165 is a reply to message #121156] Wed, 29 March 2006 14:34 Go to previous messageGo to next message
What JRE are you using? It sounds to me you may be hitting
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132378
- Jeff
Re: Not able to create RCP View/Editor style - throws [message #121174 is a reply to message #121165] Wed, 29 March 2006 14:47 Go to previous messageGo to next message
Yes I am using IBM JRE1.5. What is the solution for this?
Thanks for pointing to that defect. I thought I was doing some wrong.
Re: Not able to create RCP View/Editor style - throws [message #121183 is a reply to message #121174] Wed, 29 March 2006 16:48 Go to previous message
Unfortately we don't know what the problem is yet. All I can suggest
right now is to switch to another JRE, and add yourself as a CC to that
bug to be informed when it'll be fixed.
- Jeff
Re: Not able to create RCP View/Editor style - throws [message #612388 is a reply to message #121108] Wed, 29 March 2006 13:38 Go to previous message
Rich Kulp
Re: Not able to create RCP View/Editor style - throws [message #612393 is a reply to message #121140] Wed, 29 March 2006 14:13 Go to previous message
Target platform:
Bob
Re: Not able to create RCP View/Editor style - throws [message #612394 is a reply to message #121156] Wed, 29 March 2006 14:34 Go to previous message
- Jeff
Re: Not able to create RCP View/Editor style - throws [message #612396 is a reply to message #121165] Wed, 29 March 2006 14:47 Go to previous message
Re: Not able to create RCP View/Editor style - throws [message #612397 is a reply to message #121174] Wed, 29 March 2006 16:48 Go to previous message
- Jeff
Previous Topic:VE Palette
Next Topic:VE Palette
Current Time: Mon Jul 14 16:17:28 EDT 2025
Powered by FUDForum. Page generated in 0.12112 seconds
