Home » Modeling » GMF (Graphical Modeling Framework) » Double Click on a Node open another diagram
Double Click on a Node open another diagram [message #121094] Sun, 22 April 2007 22:32 Go to next message
Originally posted by: evaandoli.dodo.com.au
I'd like to implement double clicking on a node open another diagram, if
not present in same directory then create a "new" diagram with that name.
So a few points I guess:-
How do you pick up on a double click on a node.
How do you open another diagram from within a current diagram.
How to you automatically create a new diagram as I have the project (same as
current diagram) and file name.
Thanks for any pointers,
Stuart
Re: Double Click on a Node open another diagram [message #121104 is a reply to message #121094] Mon, 23 April 2007 00:22 Go to previous messageGo to next message
as
hiiii
few pointers :
go to *.gmfmap. rite click -> load resource. load the *.gmfmap of another
edeitor i.e which u want to open on double click.
now *.gmfmap top go top node ->node mapping properties. in properties
misc->related diagram.
select the canvas mapping of another editor.be careful while selcting as
the
canvas will have same name.
now generate *.gmfgen.
go to that toplevel node on which u want to perform double click . there
under top level node a open diagarm behaviour policy will be there.in its
properties put the GenEditorGenerator.model id & GenEdiotrView.id there.
now generate the diagarm code.
regards
varun
Re: Double Click on a Node open another diagram [message #122110 is a reply to message #121104] Fri, 27 April 2007 05:20 Go to previous messageGo to next message
Thanks for this. Had a week off but now back :-)
Just a bit of a hand with the last bit.
I see that the properties of:-
Diagram Kind:
Editor Id:
Edit Policy Name Class: <seems to be pre populated>
Open as eclipse editor: <pre populated to true>
You say set:-
I'm not quite sure where to find these Ids or what field they should go
into.
I assume GenEditorGenerator.model.id should go in Editor id (But I can't
find this class or a generated class similar)
Same with the GenEdiotrView.id << where do I find this class and where
should it go in the properties view.
Stuart
"varun" <bhatia1984@yahoo.com> wrote in message
news:0a4251db18c97d48aff930da81104e53$1@www.eclipse.org...
> as current diagram) and file name.
> hiiii
> few pointers :
> the
> regards
> varun
Re: Double Click on a Node open another diagram [message #122160 is a reply to message #122110] Fri, 27 April 2007 06:33 Go to previous messageGo to next message
hiii
You say set:-
into.
these are not classes.
in *.gmfgen u must be having GenEditorGenerator node.GenEditorGenerator
Node will have property Model Id. u have to set this id in Diagaramkind
property.
there is also GenEditorView in *.gmfgen & it has property Id.that id has
to be set in GenEditorView.id feild. this id shud be put in editor id.
These property value shud be of 2nd editor which u want to open on double
click.
regards
varun bhatia
Re: Double Click on a Node open another diagram [message #122185 is a reply to message #122160] Fri, 27 April 2007 06:59 Go to previous messageGo to next message
Thanks for that.
I was a bit confused - never really edited the .gmfgen much.
The diagram I want to open is of the same type.
I set the ids mentioned below.
I run the plugin, load the resource of the sub-diagram and attached it the
the node object.
I double click on the node object and it flashes up a no access cursor
(cirlce with a line through it) and doesn't open the diagram.
Any clues ?
can you do diagrams with the same type ?
news:0a7c06569ed98d2e0101133727eee6ca$1@www.eclipse.org...
> hiii
> You say set:-
> into.
> property.
> click.
> regards
> varun bhatia
Re: Double Click on a Node open another diagram [message #122198 is a reply to message #121104] Fri, 27 April 2007 07:14 Go to previous messageGo to next message
hiiiii
hv u set the property related diagram of that node on which u want to
perform double click in the *.gmfgraph file.
if u want to open the same editor on double click then u hv option that u
can leave the open diagram policy feilds empty.
also are u performing any single click action on ur node??
Varun Bhatia
Re: Double Click on a Node open another diagram [message #122211 is a reply to message #122198] Fri, 27 April 2007 07:21 Go to previous messageGo to next message
Thanks for your time.
I want to open up a new diagram of the same type.
The single click action just puts the properties into focus - standard
behaviour.
I have not customised anything around this.
news:76f9d91b60b08ec29892ba7183299e7e$1@www.eclipse.org...
> hiiiii
> Thanks
> Varun Bhatia
Re: Double Click on a Node open another diagram [message #122223 is a reply to message #122211] Fri, 27 April 2007 08:00 Go to previous messageGo to next message
hiiiii
hv u set related diagarm property of that node in *.gmfgraph file.
if u done that then chk ur meta- model.sthng must be wrong dere or try
debugging open diagram policy class.
hw u hv define ur meta-model for that node.That node shub also be type of
diagarm also.
u cn refer to taipan example .
varun bhatia
Re: Double Click on a Node open another diagram [message #122424 is a reply to message #122223] Fri, 27 April 2007 20:07 Go to previous messageGo to next message
Ok finally got it working thanks.
I had the top level object as a reference to my node and not that my node
was of type Top level.
Is there a way of attaching a current separately created diagram to this
node now as before I had a reference object so you could load resource and
select it.
Now its of type Top Level Node you can't do this.
I have a number of existing diagrams that I wish to load in and associate
with the nodes.
Hope this makes sense,
Stuart
news:ea8dd867dfe88aa54e9903b1f01a9148$1@www.eclipse.org...
> hiiiii
> diagarm also.
> Thanks
> varun bhatia
Re: Double Click on a Node open another diagram [message #123443 is a reply to message #122424] Wed, 02 May 2007 09:48 Go to previous messageGo to next message
hi stu
I have one ques regarding double click
My ques is ...
after generating diagram code i invoke an instance of eclipse application.
then i open my gmf editor.on double click of a daiagram element i open
another eitor.
Now i close the eclipse apllication.
Now i once againg invoke eclipse application.
Now what i found is that on both the editor diagarm element of former
editor (i.e editor from which i invoke double click) will be there & now
when i double click on the diagarm element of the editor a new editor gets
opened having diagarm element of later editor.
are u also facing the same problem.
i am trying to reslove this prob but i am nt able to resolve it.
if nt cn u tell me ur openeditpolicy & *matchingstrategy code.
thanks
Varun
Re: Double Click on a Node open another diagram [message #123484 is a reply to message #123443] Wed, 02 May 2007 10:28 Go to previous messageGo to next message
I gave up using the GMF provided open diagram option.
I didn't want my users to worry about loading resources on a top level
diagram.
Sorry Im not much help here.
I tend to not close eclipse with diagrams open as it tends to cause trouble.
news:29901d5120ff2f9ffb73490fad66719d$1@www.eclipse.org...
> hi stu
> My ques is ...
> application.
> another eitor.
> thanks
> Varun
Re: Double Click on a Node open another diagram [message #163074 is a reply to message #121104] Wed, 28 November 2007 10:17 Go to previous message
Originally posted by: frogneux.lippmann.lu
varun a écrit :
> if not present in same directory then create a "new" diagram with that
> name.
> (same as current diagram) and file name.
> hiiii
> few pointers :
> another edeitor i.e which u want to open on double click.
> the
> there under top level node a open diagarm behaviour policy will be
> there.in its properties put the GenEditorGenerator.model id &
> regards
> varun
Hi All,
Is it possible to see in the top node what we have added in the sub node.
For example, if I have two elements in sub node, I don't see anything in
the super node. Does it exist anything to resolve that?
thanks a lot
Etienne
Previous Topic:Problem when creating Mapping Model
Next Topic:What are the major alignment, minor alignment, major spacing, minor spacing, match minor size in the
Current Time: Tue Jul 22 14:39:12 EDT 2025
Powered by FUDForum. Page generated in 0.25482 seconds
