Home » Newcomers » Newcomers » Eclipse is Failing to Launch
Eclipse is Failing to Launch [message #121090] |
Thu, 01 December 2005 07:44  |
Originally posted by: russray1761.charter.net
I have Eclipse running using several plugins. I'm using version
3.2M3-win32. I downloaded Hibernate Synchronizer plugin using the update
manager. When I restart Eclipse I get the Eclipse Splash screen. However
something happens, and then I get a Dialog box telling something is wrong
with the configuration. I have remove the two directories downloaded with
Hibernate Synchronizer and re-ran the command eclipse -clean from the
command line, but I still am getting the same error. When I go check the
log file within the configuration directory I see the following:
!SESSION 2005-12-01 06:35:52.000
eclipse.buildId=I20051102-1600
java.version=1.5.0_05
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:54.421
!MESSAGE Could not install bundle plugins/org.eclipse.emf.common_2.1.0.jar
Bundle "org.eclipse.emf.common" version "2.1.0" has already been
installed from: update@plugins/org.eclipse.emf.common_2.1.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:54.453
plugins/org.eclipse.emf.ecore.xmi_2.1.0.jar Bundle
"org.eclipse.emf.ecore.xmi" version "2.1.0" has already been installed
from: update@plugins/org.eclipse.emf.ecore.xmi_2.1.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:54.484
!MESSAGE Could not install bundle plugins/org.eclipse.emf.ecore_2.1.0.jar
Bundle "org.eclipse.emf.ecore" version "2.1.0" has already been installed
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.015
plugins/org.eclipse.wst.common.frameworks.ui_1.0.0.jar Bundle
"org.eclipse.wst.common.frameworks.ui" version "1.0.0" has already been
installed from: update@plugins/org.eclipse.wst.common.frameworks.ui_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.031
plugins/org.eclipse.wst.common.frameworks_1.0.0.jar Bundle
"org.eclipse.wst.common.frameworks" version "1.0.0" has already been
installed from: update@plugins/org.eclipse.wst.common.frameworks_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.062
plugins/org.eclipse.wst.common.ui_1.0.0.jar Bundle
"org.eclipse.wst.common.ui" version "1.0.0" has already been installed
from: update@plugins/org.eclipse.wst.common.ui_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.078
plugins/org.eclipse.wst.common.uriresolver_1.0.0.jar Bundle
"org.eclipse.wst.common.uriresolver" version "1.0.0" has already been
installed from: update@plugins/org.eclipse.wst.common.uriresolver_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.125
plugins/org.eclipse.wst.dtd.core_1.0.0.jar Bundle
"org.eclipse.wst.dtd.core" version "1.0.0" has already been installed
from: update@plugins/org.eclipse.wst.dtd.core_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.187
plugins/org.eclipse.wst.rdb.dbdefinition.db2.iseries_1.0.0.j ar Bundle
"org.eclipse.wst.rdb.dbdefinition.db2.iseries" version "1.0.0" has already
been installed from:
update@plugins/org.eclipse.wst.rdb.dbdefinition.db2.iseries_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.296
plugins/org.eclipse.wst.sse.core_1.0.0.jar Bundle
"org.eclipse.wst.sse.core" version "1.0.0" has already been installed
from: update@plugins/org.eclipse.wst.sse.core_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.328
!MESSAGE Could not install bundle plugins/org.eclipse.wst.sse.ui_1.0.0.jar
Bundle "org.eclipse.wst.sse.ui" version "1.0.0" has already been
installed from: update@plugins/org.eclipse.wst.sse.ui_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.343
plugins/org.eclipse.wst.validation_1.0.0.jar Bundle
"org.eclipse.wst.validation" version "1.0.0" has already been installed
from: update@plugins/org.eclipse.wst.validation_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.390
plugins/org.eclipse.wst.xml.core_1.0.0.jar Bundle
"org.eclipse.wst.xml.core" version "1.0.0" has already been installed
from: update@plugins/org.eclipse.wst.xml.core_1.0.0/
!ENTRY org.eclipse.update.configurator 2005-12-01 06:35:55.421
!MESSAGE Could not install bundle plugins/org.eclipse.wst.xml.ui_1.0.0.jar
Bundle "org.eclipse.wst.xml.ui" version "1.0.0" has already been
installed from: update@plugins/org.eclipse.wst.xml.ui_1.0.0/
!ENTRY org.eclipse.osgi 2005-12-01 06:35:56.843
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
could not be found in the registry. The applications available are:
org.eclipse.ant.core.antRunner,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.pde.build.Build,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.junit.runtime.legacyUItestapplication,
org.eclipse.pde.junit.runtime.legacyCoretestapplication,
org.eclipse.update.core.standaloneUpdate.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:165)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2005-12-01 06:35:56.859
!MESSAGE Bundle update@plugins/com.atlassw.tools.eclipse.checkstyle_4.0.0/
[3] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-12-01 06:35:56.859
!MESSAGE Missing required bundle org.eclipse.core.resources_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.editors_0.0.0.
!MESSAGE Missing required bundle org.eclipse.team.cvs.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.team.core_0.0.0.
........ The log file continues with a list of all plugins I have saying
it could not resolve any of them.
Can someone please guide me in the steps I need to take to fix this
problem?
Thank you for reading my post. Any suggestions would be greatly
appreciated.
Re: Eclipse is Failing to Launch [message #121280 is a reply to message #121090] |
Fri, 02 December 2005 05:46   |
Can some please help me? I am completely shutdown and can not use Eclipse
whatsoever.
Thank you!
"Russ Ray" <russray1761@charter.net> wrote in message
news:eee94b093a5f4d309f6630df98a612cd$1@www.eclipse.org...
> !SESSION 2005-12-01
> 06:35:52.000 -----------------------------------------------
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Bundle "org.eclipse.emf.common" version "2.1.0" has already been installed
> from: update@plugins/org.eclipse.emf.ecore_2.1.0/
> Bundle "org.eclipse.wst.sse.ui" version "1.0.0" has already been installed
> Bundle "org.eclipse.wst.xml.ui" version "1.0.0" has already been installed
> !STACK 1
> at
> at
> at
> problem?
> appreciated.
Re: Eclipse is Failing to Launch [message #121287 is a reply to message #121090] |
Fri, 02 December 2005 06:59   |
From what I can seeing by "googling" this, I receive the link
http://help.eclipse.org/help30/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/product_def_extpt.htm
> !SESSION 2005-12-01
> !STACK 1
> at
> at
> at
> problem?
> appreciated.
Re: Eclipse is Failing to Launch [message #121471 is a reply to message #121090] |
Sat, 03 December 2005 12:34  |
For the good of the group:
The problem I was having involving this error:
was related to the fact I had 3rd party jars inside the eclipse plugin
directory and also in the 3rd party directory. When I removed the jar file
from the eclipse/plugin direct and allowed Eclipse to locate the jar file
from within the 3rd party directory--eclipse/plugins/<3rdpartydirectory>
this error went away!
> !SESSION 2005-12-01
> !STACK 1
> at
> at
> at
> problem?
> appreciated.
Current Time: Mon Jul 21 21:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.31320 seconds
