ctrl-c ctrl-v not working in 3.5 [message #11063] |
Mon, 13 July 2009 14:19  |
Originally posted by: jpeltzer.rossvideo.com
Has anyone else had the ctrl-x/ctrl-c/ctrl-v keys stop working in Eclipse
3.5?
They used to work perfectly in my Swing text fields but not anymore.
I have tried this on Java 6 u6 and Java 6 u14.
Confirmation or denials are both welcome responses.
James
Re: ctrl-c ctrl-v not working in 3.5 [message #12478 is a reply to message #12453] |
Thu, 16 July 2009 13:14  |
Thanks for the heads up. I'll repost over there given that this thread
hasn't gotten a lot of action over the past 3 days.
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:h3na47$fq1$1@build.eclipse.org...
> If you don't get an answer here then you should ask this on the
> eclipse.platform newsgroup. I know that at least until 3.4.x that one
> step
> that was taken in reaction to Ctrl+C/V/W was to introspect on the focus
> control for copy()/cut()/paste() methods, and this was done specifically
> to
> handle the case of a Swing control like a text field having focus. I'm
> pretty sure that this would not have been intentionally changed in 3.5, so
> there may be a regression that Eclipse UI needs to investigate.
> Grant
> "James Peltzer" <jpeltzer@rossvideo.com> wrote in message
> news:h3kkp6$uh8$1@build.eclipse.org...
>> After further testing/investigation,
>> To get these keys back, I had to disable the key filter in the
>> IBindingService. Apparently this will prevent all key bindings from
> working
>> (not an overly great solution). Any better workarounds out there?
>> James
>> news:h3ftvl$7f6$1@build.eclipse.org...
> Eclipse
>> > 3.5?
>> > Thanks,
>> > James
Re: ctrl-c ctrl-v not working in 3.5 [message #575299 is a reply to message #11063] |
Wed, 15 July 2009 09:15  |
IBindingService. Apparently this will prevent all key bindings from working
James
> 3.5?
> James
Re: ctrl-c ctrl-v not working in 3.5 [message #575317 is a reply to message #11074] |
Thu, 16 July 2009 09:31  |
eclipse.platform newsgroup. I know that at least until 3.4.x that one step
control for copy()/cut()/paste() methods, and this was done specifically to
Grant
working
> James
Eclipse
> > 3.5?
> > Thanks,
> > James
Re: ctrl-c ctrl-v not working in 3.5 [message #575362 is a reply to message #12453] |
> step
> to
> Grant
> working
>> James
> Eclipse
>> > 3.5?
>> > Thanks,
>> > James
FUDForum. Page generated in 0.03858 seconds
