adapter factory problem while porting to wtp1.0m5 [message #120801] |
Thu, 14 July 2005 10:42  |
hello guys,
i am currently porting the orangevolt xslt plugin to wtp1.0m5.
everything works fine now except that i get an error when my own
structurededitor based xml editor is opening.
then a error messagebox labeled with "there was a problem adding adapter
factories." occures. after pressing ok everything works fine.
my editor overlays the contentoutlineconfiguration using
<extension point = "org.eclipse.ui.editors">
<editor
id = "com.orangevolt.xslt.editor.XMLEditor"
name = "Orangevolt XML Editor"
icon = "icons/xslt-16.gif"
extensions = "xml,xsl,xslt"
default="true"
class = "com.orangevolt.xslt.editor.XMLEditor">
</editor>
</extension>
in the plugin xml.
i debugged deeper into wtp and the problem seems to me a result of a
backward compatibility issue ? :
inside org.eclipse.wst.sse.ui.internal.editor.EditorModelUtil:
* ContentType might have already been checked above, this
* check is here for backwards compatability for those that
* don't specify a content type
if (provider.isFor(structuredModel.getModelHandler())) {
Platform.run(new SafeRunnable(SSEUIMessages.EditorModelUtil_1) {
//$NON-NLS-1$
public void run() {
provider.addAdapterFactories(structuredModel);
afterall here is the stacktrace i got:
java.lang.NoSuchFieldError: LoadingReferencedGrammars
org.eclipse.wst.xml.ui.internal.DOMObserver$TimerJob.<init>(DOMObserver.java:133)
at org.eclipse.wst.xml.ui.internal.DOMObserver.<init>(DOMObserver.java:145)
org.eclipse.wst.xml.ui.internal.registry.AdapterFactoryProvi derForXML.addContentBasedFactories(AdapterFactoryProviderFor XML.java:77)
org.eclipse.wst.xml.ui.internal.registry.AdapterFactoryProvi derForXML.addAdapterFactories(AdapterFactoryProviderForXML.j ava:45)
org.eclipse.wst.sse.ui.internal.editor.EditorModelUtil$1.run (EditorModelUtil.java:66)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.wst.sse.ui.internal.editor.EditorModelUtil.addFa ctoriesTo(EditorModelUtil.java:64)
org.eclipse.wst.sse.ui.internal.StructuredTextEditor.doSetIn put(StructuredTextEditor.java:1190)
org.eclipse.ui.texteditor.AbstractTextEditor$16.run(Abstract TextEditor.java:2360)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2134)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:2378)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:2405)
org.eclipse.wst.sse.ui.internal.StructuredTextEditor.init(St ructuredTextEditor.java:1759)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:773)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:572)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:258)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1216)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:944)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:939)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2535)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1819)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2566)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1503)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:700)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
the strange thing is that when i disable my xml editor plugin everything
works fine...
can anybody help me out ?
many regards,
lars
Re: adapter factory problem while porting to wtp1.0m5 [message #120840 is a reply to message #120818] |
Thu, 14 July 2005 12:24  |
ooops again - my fault:
forget my last mail - the error is fixed in wtp-sdk-I20050711.
the error described by myself was a result of my error prone self
written uri resolver.
sorry,
lars
lars gersmann wrote:
> oooops - was a "halloo till you're out of the wood" :-(
> in current i-build (wtp-sdk-I20050711) the bug is always alive - but the
> behaviour changed :
> when i use my extended xml editor everything works fine until i edit an
> xml file with applied schema. in this case everytime the autocompletion
> was activated (ctrl-space) the error dialog comes up.
> any suggestions ?
> many regards,
> lars
>> hello guys,
>> adapter factories." occures. after pressing ok everything works fine.
>> <editor
>> default="true"
>> </editor>
>> </extension>
>> in the plugin xml.
>> this
>> that
>> Platform.run(new
>> SafeRunnable(SSEUIMessages.EditorModelUtil_1) { //$NON-NLS-1$
>> public void run() {
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> everything works fine...
>> many regards,
>> lars
FUDForum. Page generated in 0.18279 seconds
