A question about perspective extension [message #120718] |
Tue, 25 November 2003 04:04 |
Originally posted by: xiaoyang.ma.hingesoftware.com
hi, there:
I am tring to create a new perspective in my plugin project but I
encountered a question. I have added the perspective definition into the
plugin.xml below:
<extension
point="org.eclipse.ui.perspectives">
<perspective
id="com.test.testPerspective"
name="VBRD"
class="com.test.TestPerspective">
</perspective>
</extension>
The class TestPerspective's code is here:
package com.test;
import org.eclipse.ui.IPageLayout;
import org.eclipse.ui.IPerspectiveFactory;
import org.eclipse.ui.IFolderLayout;
public class TestPerspective implements IPerspectiveFactory {
public static final String ID_REPORT_ORGANIZER_VIEW =
"com.viador.MovingBoxView";
public void createInitialLayout(IPageLayout layout) {
layout.setEditorAreaVisible(false);
System.out.println("TestPerspective");
String editorArea = layout.getEditorArea();
IFolderLayout topLeft = layout.createFolder("topLeft", IPageLayout.LEFT,
0.25f, editorArea);
topLeft.addView(IPageLayout.ID_RES_NAV);
topLeft.addPlaceholder(IPageLayout.ID_BOOKMARKS);
IFolderLayout bottomLeft =
"bottomLeft",
IPageLayout.BOTTOM,
0.50f,
"topLeft");
bottomLeft.addView(IPageLayout.ID_OUTLINE);
bottomLeft.addView(IPageLayout.ID_PROP_SHEET);
layout.addView(ID_REPORT_ORGANIZER_VIEW, IPageLayout.BOTTOM, 0.66f,
editorArea);
I have not see the proper view was opened and in console no anything was
output although there is a calling for "System.out" in the
createInitialLayout() method. I think this method is not called as it is
expected. But the perspective is in the "window->open
perspective->others..." list.
What's wrong with my code?
Thanks so much!
Alex Ma
FUDForum. Page generated in 0.03606 seconds
