Home » Archived » Visual Editor (VE) » properties of TableColumn
properties of TableColumn [message #120480] Mon, 13 March 2006 11:09
Originally posted by: markus.wawra.shark-soft.com
I've a problem with a class called STTableColumn, a subclass of
TableColumn. I want to create an entry in the Property Sheet. So I tried
to write a set and get method the common way. Nevertheless it's not in the
properties.
If I do the same for an other class like STPanel, which extends JPanel, it
works perfectly.
Where is the problem?
Markus
Previous Topic:ScrolledComposite problems
Next Topic:properties of TableColumn
Current Time: Sat Jul 12 14:06:28 EDT 2025
Powered by FUDForum. Page generated in 1.02250 seconds
