Home » Language IDEs » C / C++ IDE (CDT) » org.eclipse.cdt.utils- Plugin
org.eclipse.cdt.utils- Plugin [message #120342] Thu, 09 September 2004 01:35 Go to next message
Originally posted by: maranan.coolgoose.com
Hi all,
May I know where "org.eclipse.cdt.utils" plug-in is available? It is
not available with cdt.
When I tried to compile a piece of code, I got the error "package
org.eclipse.cdt.utils.ui.controls does not exist". That is the reason
why I am looking for this particular plugin.
Maranan
Re: org.eclipse.cdt.utils- Plugin [message #120456 is a reply to message #120342] Thu, 09 September 2004 09:27 Go to previous messageGo to next message
It is not a plugin, the package can be found in the cdt.ui plugin. Its
under it own source directory "utils.ui", check your java project build
paths and make sure it did not get removed as a source path. Or you can
use the PDE Tools -> Update classpath... in the context menu (right
click) on the cdt.ui plugin project to fix this.
Dave.
maranan wrote:
> Hi all,
> Maranan
Re: org.eclipse.cdt.utils- Plugin [message #120624 is a reply to message #120456] Fri, 10 September 2004 01:04 Go to previous message
Thanks Dave.
Lemmme try this..
Maranan
> Dave.
> maranan wrote:
>> Hi all,
>> Thanks,
>> Maranan
Previous Topic:How to implements IManagedBuilderMakefileGenerator
Next Topic:private in cdt
Current Time: Fri Jul 25 11:01:00 EDT 2025
Powered by FUDForum. Page generated in 0.26569 seconds
