Home » Archived » Test and Performance Tools Platform (TPTP) » NullPointerException at doubleClick
NullPointerException at doubleClick [message #120271] Tue, 08 January 2008 11:26 Go to next message
hi there,
i wanna use eclipse tptp, static analysis and wrote zwo rules, but i
always get a nullpointerexception when i doubleclick on the result.
i have no idea what to do.
http://www.eclipse.org/tptp/home/documents/process/developme nt/static_analysis/TPTP_static_analysis_tutorial_part3.html
can someone help me?
stacktrace:
org.eclipse.tptp.platform.analysis.core.ui.internal.views.Re sultsViewSelection.doubleClick(ResultsViewSelection.java:54)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1387)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: NullPointerException at doubleClick [message #120313 is a reply to message #120271] Wed, 09 January 2008 03:05 Go to previous message
After debugging the source code from cvs, I recognized that
((AbstractAnalysisRule)result.getOwner()).getViewer() in
org.eclipse.tptp.platform.analysis.core.ui evaluated to null so that the
NullPointerException was thrown.
The tutorial on
says: "Viewers can be attached to any analysis element for the purposes of
rendering rule result data."
So, where can I set the viewer, the API doesn't define a setter-Method for
AbstractAnalysisElement ?
( http://archive.eclipse.org/tptp/4.2.0/javadoc/Platform/publi c/org/eclipse/tptp/platform/analysis/core/element/AbstractAn alysisElement.html)
Previous Topic:BIRT classpath issue when publishing report
Next Topic:Profiling error with weblogic 9.2
Current Time: Wed Nov 05 03:59:59 EST 2025
Powered by FUDForum. Page generated in 0.03760 seconds
