Home » Language IDEs » Java Development Tools (JDT) » problems with String.split(String)
problems with String.split(String) [message #120249] |
Mon, 24 November 2003 11:34  |
Originally posted by: pavel.math.utexas.edu
I am having problems using the method java.util.String.split(String) which
is supposed to split up
a string into an array of strings while cutting out a delimiter. For some
reason, when I use it, it
gives me an error. Could someone advise me as to how I should approach
this problem? I am
using the 2.12 build of Eclipse and the OS is Apple's Mac OS X 10.2.8.
Thank you.
Sincerely,
Paul Gribeluyk
Re: problems with String.split(String) [message #120286 is a reply to message #120249] |
Mon, 24 November 2003 12:16   |
Originally posted by: rsk.email.arizona.edu
Paul, we need some more details. What isn't working? What is the error?
Do you get an exception? What is it?
Split does work how you mentioned, so take the sentence:
"I like dogs" and do this:
String[] array = "I like dogs".split(" ");
this will return me:
array[0] = "I";
array[1] = "like";
array[2] = "dogs";
Is this how you are using it? Split TAKES a regular expression, so its
handy that most of the time simple characters will work, but if you pass
in soemthing like "?" which is a reserved character for regular
expressions, then you need to escape it "\\?" if you actually wanted to
split on question marks.
Best,
-Riyad
Paul Gribelyuk wrote:
> Hello,
> this problem? I am
> Thank you.
> Sincerely,
> Paul Gribeluyk
Re: problems with String.split(String) [message #120653 is a reply to message #120286] |
Mon, 24 November 2003 23:29   |
So here is how I use split:
BufferedReader buffread1 = new BufferedReader (new FileReader ( in1));
String exp = buffread1.readLine();
String [] expvalues = exp.split(",");
The file in1 contains double values, two per line, separated by commas.
The error message that I
get is this:
"the method split(String) is undefined for the type String"
Thank you for the help.
Paul Gribelyuk
> array[0] = "I";
> array[1] = "like";
> array[2] = "dogs";
> expressions, then you need to escape it "\?" if you actually wanted to
> Best,
> -Riyad
> > Hello,
> > this problem? I am
> > Thank you.
> > Sincerely,
> > Paul Gribeluyk
Re: problems with String.split(String) [message #120664 is a reply to message #120653] |
Mon, 24 November 2003 23:51   |
It would appear that you are compiling against 1.3 libraries.
String.split(String) was added in 1.4
HTH
Darins
"Paul Gribelyuk" <pavel@math.utexas.edu> wrote in message
news:bpulqn$8e0$1@eclipse.org...
> get is this:
> Cheers,
> Paul Gribelyuk
> > array[0] = "I";
> > array[1] = "like";
> > array[2] = "dogs";
> > Best,
> > -Riyad
> > > Hello,
which
some
approach
> > > this problem? I am
> > > Thank you.
> > > Sincerely,
> > > Paul Gribeluyk
Re: problems with String.split(String) [message #120675 is a reply to message #120664] |
Mon, 24 November 2003 23:53   |
ditto
> HTH
> Darins
>>get is this:
>>Cheers,
>>Paul Gribelyuk
>>>array[0] = "I";
>>>array[1] = "like";
>>>array[2] = "dogs";
>>>Best,
>>>-Riyad
>>>>Hello,
> which
> some
> approach
>>>>this problem? I am
>>>>Thank you.
>>>>Sincerely,
>>>>Paul Gribeluyk
Re: problems with String.split(String) [message #121901 is a reply to message #120664] |
Tue, 25 November 2003 15:23   |
So I guess my next question would be how to fix it. I've downloaded the
1.4 libraries, but I'm not
sure how to let eclipse know that. Any ideas?
Paul Gribelyuk
> HTH
> Darins
> > get is this:
> > Cheers,
> > Paul Gribelyuk
> > > array[0] = "I";
> > > array[1] = "like";
> > > array[2] = "dogs";
> > > expressions, then you need to escape it "?" if you actually wanted to
> > > Best,
> > > -Riyad
> > > > Hello,
> which
> some
> approach
> > > > this problem? I am
> > > > Thank you.
> > > > Sincerely,
> > > > Paul Gribeluyk
Re: problems with String.split(String) [message #123964 is a reply to message #121901] |
Tue, 02 December 2003 17:19  |
Originally posted by: John_Arthorne.oti.com_
You need to configure Eclipse to use this as your JRE. Look under
Preferences > Java > Installed JREs. Add the 1.4 JRE and set it as the
default JRE.
Current Time: Tue Jul 15 02:59:04 EDT 2025
Powered by FUDForum. Page generated in 0.10931 seconds
