Version Control System [message #120219] |
Sat, 26 April 2008 11:07  |
Hi Martin,
When I generate my Hibernate mapping file, I get the version attribute.
Changing the data in the database creates new version of the objects.
I have some questions about this:
1. Can I use this feature and create a Version Control
application/database (similar to a source control) but for a complete
model? After all there are relation to maintain and it could be of
several levels and I would to be able to version it and retrieve a
certain version that includes the relations at that version.
2. Where can I read more about this?
Yigal
Re: Version Control System [message #120460 is a reply to message #120447] |
Mon, 28 April 2008 16:13  |
Originally posted by: stepper.sympedia.de
Martin Taal schrieb:
> Hi Eike,
> Yes that's a nice idea. However what I am not sure about is how to
> handle foreign key relations in the db using versioning. Afaiu the
> version number needs to be part of the primary key and foreign keys.
> But I can't really imagine how foreign keys can work when the target
> object is updated and a new version is stored in the db.
> How is this done in cdo?
In CDO the foreign keys are not versioned. In general entities are not
looked up via version but via timestamp to get a consistent view across
all entities. This is called an audit view. A normal view that sees the
latest versions (like a floating label) is also available. It will be
necessary to add two timestamp columns (created and revised).
Do you think that would be feasible with Hibernate?
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hi Martin,
>> As you know CDO supports transparent versioning if the configured
>> store can do that. Do you think we should give it a try and enhance
>> the HibernateStore such that transparent versioning is supported out
>> of the box?
>> Cheers
>> /Eike
>>> Hi Yigal,
>>> Afaik the hibernate versioning is really for optimistic locking and
>>> nothing more. I think to get complete versioning (to call it that)
>>> you would need to implement/model it explicitly. Hibernate has some
>>> concepts which can be helpfull (interceptors/eventlisteners for
>>> example). Maybe this blog can give some tips:
>>> http://hacimbengali.blogspot.com/2007/05/versionierung-von-d atenbank-entitten.html
>>> gr. Martin
>>> Yigal wrote:
>>>> Hi Martin,
>>>> attribute. Changing the data in the database creates new version
>>>> of the objects.
>>>> complete model? After all there are relation to maintain and it
>>>> could be of several levels and I would to be able to version it and
>>>> retrieve a certain version that includes the relations at that
>>>> version.
>>>> Thanks
>>>> Yigal
Re: Version Control System [message #617926 is a reply to message #120219] |
Sun, 27 April 2008 16:30  |
Hi Yigal,
Afaik the hibernate versioning is really for optimistic locking and nothing more. I think to get
complete versioning (to call it that) you would need to implement/model it explicitly. Hibernate has
some concepts which can be helpfull (interceptors/eventlisteners for example). Maybe this blog can
give some tips:
gr. Martin
Yigal wrote:
> Hi Martin,
> Thanks
> Yigal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Version Control System [message #617928 is a reply to message #120259] |
Mon, 28 April 2008 02:30  |
Hi Martin,
As you know CDO supports transparent versioning if the configured store
can do that. Do you think we should give it a try and enhance the
HibernateStore such that transparent versioning is supported out of the box?
Cheers
/Eike
> Hi Yigal,
> nothing more. I think to get complete versioning (to call it that) you
> gr. Martin
> Yigal wrote:
>> Hi Martin,
>> attribute. Changing the data in the database creates new version of
>> the objects.
>> Thanks
>> Yigal
Re: Version Control System [message #617940 is a reply to message #120285] |
Mon, 28 April 2008 15:57  |
Hi Eike,
Yes that's a nice idea. However what I am not sure about is how to handle foreign key relations in
the db using versioning. Afaiu the version number needs to be part of the primary key and foreign
keys. But I can't really imagine how foreign keys can work when the target object is updated and a
gr. Martin
Eike Stepper wrote:
> Hi Martin,
> box?
> Cheers
> /Eike
>> Hi Yigal,
>> gr. Martin
>> Yigal wrote:
>>> Hi Martin,
>>> the objects.
>>> Thanks
>>> Yigal
The Netherlands
Re: Version Control System [message #617941 is a reply to message #120447] |
> Hi Eike,
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hi Martin,
>> of the box?
>> Cheers
>> /Eike
>>> Hi Yigal,
>>> gr. Martin
>>> Yigal wrote:
>>>> Hi Martin,
>>>> of the objects.
>>>> version.
>>>> Thanks
>>>> Yigal
FUDForum. Page generated in 0.05242 seconds
