Home » Language IDEs » C / C++ IDE (CDT) » private in cdt
private in cdt [message #120168] Wed, 08 September 2004 12:20 Go to next message
Originally posted by: hmetu.gmx.net
Hi!
I am using cdt2.0.1 with MinGW under eclipse and wenn I write my codes in
c++ and try to build errors (variable is private). Does it mean that
variables cannot be
declared as private here? How do I go about this?
Thanks in anticipation
Harp
Re: private in cdt [message #120481 is a reply to message #120168] Thu, 09 September 2004 11:31 Go to previous messageGo to next message
Hi!
May be I did not compose my question well, I have the following code!
class phonebook {
char name[80];
int areacode;
int prefix;
int num;
public:
phonebook(char *n, int a, int p, int nm)
strcpy(name,n);
areacode = a;
prefix = p;
num = nm;
friend ostream &operator<<(ostream &stream, phonebook o);
At the declarations of name, areacode,... the compiler indicates that they
are private (correct), but it refuses to build. Does it mean that a variable
cannot be declared private?
Harp
"Harp" <hmetu@gmx.net> wrote in message news:chnb9u$rnc$1@eclipse.org...
> Hi!
> variables cannot be
> Harp
Re: private in cdt [message #120522 is a reply to message #120481] Thu, 09 September 2004 12:30 Go to previous messageGo to next message
Harp,
I don't think anyone has answered because this sounds like a
programmer/compiler problem, not a CDT problem. If you are asking
whether or not you can declare a variable as private and initialize it
inside a constructor, then the answer is "of course". Feel free to post
your compiler error if you think this is a CDT problem, though.
Sean
Harp wrote:
> Hi!
> class phonebook {
> char name[80];
> int areacode;
> int prefix;
> int num;
> public:
> strcpy(name,n);
> areacode = a;
> prefix = p;
> num = nm;
> Thanks
> Harp
>>Hi!
>>variables cannot be
>>Harp
Re: private in cdt [message #120637 is a reply to message #120522] Fri, 10 September 2004 03:05 Go to previous message
Hi Sean!
Thanks for your concern, you are right, it was a compiler error, the wrong
library was imported....
Harp
"Sean Evoy" <sevoy@ca.ibm.com> wrote in message
news:chq080$47h$1@eclipse.org...
> Harp,
> Sean
> Harp wrote:
> > Hi!
> > class phonebook {
> > char name[80];
> > int areacode;
> > int prefix;
> > int num;
> > public:
> > strcpy(name,n);
> > areacode = a;
> > prefix = p;
> > num = nm;
they
variable
> > Thanks
> > Harp
> >>Hi!
in
> >>variables cannot be
> >>Harp
Previous Topic:org.eclipse.cdt.utils- Plugin
Next Topic:More debugging exceptions
Current Time: Thu Jul 17 13:19:41 EDT 2025
Powered by FUDForum. Page generated in 0.05635 seconds
