Re: issue with start levels in launch config? [message #903058 is a reply to message #902986] |
Tue, 21 August 2012 18:39 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Henrik,
I assume that the issue is caused by the builder where some resource
service providers shall be instantiated?
I think we need to listen to changes in the registered bundles in order
to deregister pending extension. That would probably do the trick.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 21.08.12 16:22, schrieb Henrik Lindberg:
> I have a problem, and I think it has to do with start levels in the
> launch configuration I am using when developing.
> If I have a dirty editor and exit, I get a question if I want to save.
> If I answer ok, the builder kicks in, and then it runs into problems
> because some bundle(s) have been deactivated.
> How can I figure out which bundles need "auto-start" or some start level
> set?
> e.g. the stacktrace I am looking at right now was caused by
> org.eclipse.xtext.builder.internal.Activator.getDefault() returning null.
> Hints how to fix this? It is very annoying when developing.
> It seems to be ok in the built product, so I am not in panic :)
> Regards
> - henrik
FUDForum. Page generated in 0.04471 seconds
