Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with setBlockOnOpen in Dialog
Problem with setBlockOnOpen in Dialog [message #120143] Fri, 30 January 2009 03:51 Go to next message
Hello
I found a problem with setBlockOnOpen method. When you create a dialog the
default strategy is to block the open method until the dialogs window
closes. But if we will not close dialog and refresh window the session id
will be the same so the locked UI thread will be used. So the user will
not be able to restart the application.
As possible solution I can not to block the UI thread and do it after I
call open member manually. So I have two questions:
1) Is it a bug?
2) If not - is it possible to find platform-independent solution?
Re: Problem with setBlockOnOpen in Dialog [message #120462 is a reply to message #120143] Wed, 04 February 2009 12:27 Go to previous messageGo to next message
Igor,
I haven't encountered yet what you describe. If you can reproduce it
with a self-contained snippet, feel free to file a bug report. If it
is of interest, see here for a bug-reporting how-to:
http://wiki.eclipse.org/RAP_Bug_Reporting_Howto.
Rüdiger
Igor Pavlenko wrote:
> Hello
> the default strategy is to block the open method until the dialogs
> window closes. But if we will not close dialog and refresh window the
> session id will be the same so the locked UI thread will be used. So the
> user will not be able to restart the application.
> 1) Is it a bug?
Re: Problem with setBlockOnOpen in Dialog [message #120620 is a reply to message #120462] Thu, 05 February 2009 15:11 Go to previous messageGo to next message
Hello
Lets create a simple dialog:
public class DemoDialog extends Dialog
protected DemoDialog(Shell parentShell)
super(parentShell);
protected void configureShell(Shell newShell)
super.configureShell(newShell);
newShell.setText("Demo dialog");
protected Control createDialogArea(Composite parent)
Composite composite = (Composite)super.createDialogArea(parent);
Label label = new Label(composite, SWT.NONE);
label.setText("Refresh your browser");
return composite;
Lets create somewhere two different buttons with two different selection
listeners:
Button button1 = new Button(parent, SWT.NONE);
button1.setText("Open dialog");
button1.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
DemoDialog demoDialog = new DemoDialog(parent.getShell());
demoDialog.open();
Button button2 = new Button(parent, SWT.NONE);
button2.setText("Open dialog with ProgressMonitorDialog");
button2.addSelectionListener(new SelectionAdapter()
final ProgressMonitorDialog progressDialog =
new ProgressMonitorDialog(parent.getShell());
try
progressDialog.run(true, false, new IRunnableWithProgress()
public void run(final IProgressMonitor monitor)
throws InvocationTargetException, InterruptedException
monitor.beginTask(
"Show dialog task", IProgressMonitor.UNKNOWN);
final DemoDialog demoDialog =
new DemoDialog(progressDialog.getShell());
parent.getDisplay().syncExec(new Runnable()
public void run()
demoDialog.open();
monitor.done();
catch (InvocationTargetException e1)
e1.printStackTrace();
catch (InterruptedException e1)
Use first button to open dialog. Refresh browser. Everithing is fine.
Use second button to open dialog. Refresh browser.
org.eclipse.swt.SWTException: Failed to execute runnable
(org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadTer minatedError)
will be thrown.
I can post this bug to bugzilla if it necessary.
Igor
Re: Problem with setBlockOnOpen in Dialog [message #120631 is a reply to message #120620] Fri, 06 February 2009 02:10 Go to previous messageGo to next message
Hi Igor,
we can confirm the erroneous behaviour. But I'm not sure if this is
dependent on setBlockOnOpen(true). We're using setBlockOnOpen(false) and
get the same exception when we refresh the browser.
Regards, Lars
> Hello
> super(parentShell);
> return composite;
> listeners:
> demoDialog.open();
> try
> monitor.beginTask(
> public void run()
> demoDialog.open();
> monitor.done();
> will be thrown.
> Igor
Re: Problem with setBlockOnOpen in Dialog [message #120669 is a reply to message #120620] Fri, 06 February 2009 03:43 Go to previous messageGo to next message
Igor,
what you describe might be a duplicate of
258102: ProgressMonitorDialog causes an Exception on page reload
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258102
Can you confirm this?
Rüdiger
> Hello
> super(parentShell);
> return composite;
> listeners:
> demoDialog.open();
> try
> monitor.beginTask(
> public void run()
> demoDialog.open();
> monitor.done();
> will be thrown.
> Igor
Re: Problem with setBlockOnOpen in Dialog [message #120700 is a reply to message #120669] Fri, 06 February 2009 04:04 Go to previous message
It seems so. It is the same problem.
Previous Topic:File Upload and Download in RWT standalone
Next Topic:Register PespectiveListener
Current Time: Thu Jul 17 19:51:42 EDT 2025
Powered by FUDForum. Page generated in 0.07506 seconds
