Home » Language IDEs » Java Development Tools (JDT) » Controlling code formatter
Controlling code formatter [message #120138] Mon, 24 November 2003 10:20 Go to next message
Originally posted by: bill.otherwiseDELETE.com
I often add extra spaces within a line of code to help format it and increase
readability. The Format option removes all my extra whitespace.
Is there a way to have finer control over what the code formatter does? In
reality I would be happy if it just indented the code correctly and left
everything else as I have it.
Thanks for any suggestions.
Bill Tschumy
Otherwise -- Austin, TX
http://www.otherwise.com
Re: Controlling code formatter [message #120150 is a reply to message #120138] Mon, 24 November 2003 10:26 Go to previous messageGo to next message
The new formatter will offer many more options once its preference page
is complete.
For just indenting, try Source->Correct Indentation (Ctrl+I). If the
Java->Work in Progress->Smart Tab preference is on, you can simply type
TAB at the beginning of a line to get the correct indentation.
-tom
Re: Controlling code formatter [message #120173 is a reply to message #120138] Mon, 24 November 2003 10:37 Go to previous messageGo to next message
Originally posted by: rsk.email.arizona.edu
Bill,
Since 2.x series there is a formatter option "Remove Blank Lines", make
sure to uncheck this, or else Eclipse Ends up compacting everything.
Best,
-Riyad
Re: Controlling code formatter [message #120262 is a reply to message #120138] Mon, 24 November 2003 11:49 Go to previous messageGo to next message
Originally posted by: kc.baltz.Lollimail.com
It looks like Jalopy, a source-code formatter, plugs in to Eclipse. It
has very fine-grained control.
http://jalopy.sourceforge.net/plugins.html
K.C.
Re: Controlling code formatter [message #120347 is a reply to message #120150] Mon, 24 November 2003 13:52 Go to previous message
On Mon, 24 Nov 2003 9:26:49 -0600, Tom Eicher wrote
(in message <bpt7rj$m10$1@eclipse.org>):
>> increase
>> In
> is complete.
> -tom
Thanks, I was using a build from a month or so ago and these features did
not appear in it. I downloaded 3.0M5 and all is golden.
Bill Tschumy
Previous Topic:Need to limit imports - Eclipse 2.1.2
Next Topic:Any Swing Visual Composition tool available in Eclipse?
Current Time: Sat Jul 26 20:15:18 EDT 2025
Powered by FUDForum. Page generated in 0.06195 seconds
