Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling launch process timeout
Profiling launch process timeout [message #120128] Thu, 03 January 2008 10:10 Go to next message
Originally posted by: lou.parisi.photomask.com
I have a new install of eclipse 3.3.1.1 (eclipse.buildId=M20071023-1652),
TPTP-4.4.0.3 all in one sdk, and java.version=1.5.0_09. I created a
simple test application to do profiling and it worked fine doing the
profiling within the eclipse IDE. I then tried to profile my larger
project and I was getting the timeout message below. I then took the code
from my simple test project that was working in its own project and copied
the entire package structure to the source directory of my larger project.
When I try to run the same profiling task on the simple test code copied
to the larger project it gets the same timeout error but works when it is
in a project by itself.
I searched bugzilla and the last few months of the newsgroup for timeout
keyword but did not see issue discussed. Can you give me any guidance on
this issue?
-------------- timeout error ----------------------------
org.eclipse.core.runtime.CoreException
A time-out occurred while attempting to launch the process
org.eclipse.core.runtime.CoreException: A time-out occurred while
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:596)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:512)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:312)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Thread.java:595)
Re: Profiling launch process timeout [message #120142 is a reply to message #120128] Thu, 03 January 2008 10:40 Go to previous messageGo to next message
I had only searched the last few months of newsgroup messages before posting
this but found the same issue posted to this newsgroup on July 3, 2007 by
Tom Funk with no apparent resolution.
Also, the profiling is giving the same error for all analysis modes.
"Lou Parisi" <lou.parisi@photomask.com> wrote in message
news:1ce0beb080c0cb10279205cf82f62d11$1@www.eclipse.org...
>TPTP-4.4.0.3 all in one sdk, and java.version=1.5.0_09. I created a simple
>test application to do profiling and it worked fine doing the profiling
>within the eclipse IDE. I then tried to profile my larger project and I
>was getting the timeout message below. I then took the code from my simple
>test project that was working in its own project and copied the entire
>package structure to the source directory of my larger project. When I try
>to run the same profiling task on the simple test code copied to the larger
>project it gets the same timeout error but works when it is in a project by
>itself.
> this issue?
> at
> at
> at
> at
> at
> at
> at
> at
Re: Profiling launch process timeout [message #120180 is a reply to message #120128] Fri, 04 January 2008 04:03 Go to previous messageGo to next message
Originally posted by: mauro.molinari.cardinis.com
Hi Lou,
I don't know if your issue is the same I had some time ago (in my case,
I couldn't profile ANYTHING, neither a simple "HelloWorld" application),
anyway you might check this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201474
It's solved in 4.4.1.
I would also suggest you to try the stand-alone agent controller and see
if it works better than the integrated one...
Mauro.
Re: Profiling launch process timeout [message #120443 is a reply to message #120128] Thu, 10 January 2008 01:41 Go to previous message
Could you try any last 4.5 TPTP build?
Igor
Previous Topic:Linux System Trace - What does it do?
Next Topic:Unable to connect Integrated Agent Controller
Current Time: Mon Sep 01 01:24:03 EDT 2025
Powered by FUDForum. Page generated in 0.03851 seconds
