Re: P2 Installation of feature fails because of unsatisfied capability [message #120107] |
Thu, 23 October 2008 14:31 |
Originally posted by: zx.code9.com
Alexander Nyßen wrote:
> Hallo,
> I managed to install my feature-based RCP (which contains the complete
> Eclipse SDK) via the p2 director application.
> However, now I want to install an additional feature (sc.viper.ide.test)
> to the product via the p2 director application. This time, the
> installation fails. The .log file says:
> !ENTRY org.eclipse.equinox.p2.director 4 0 2008-10-23 17:20:37.448
> !MESSAGE Problems resolving provisioning plan.
> !SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2008-10-23 17:20:37.448
> !MESSAGE No solution found because the problem in /tmp/p2Encoding720.opb is
> unsatisfiable.
> !ENTRY org.eclipse.equinox.p2.director 4 1 2008-10-23 17:20:41.328
> !MESSAGE Cannot find a solution satisfying the following requirements
> Match[requiredCapability:
> org.eclipse.equinox.p2.iu/javax.servlet/[2.3.0.v200806031603 ,2.3.0.v200806031603]]
> The config.ini of my RCP is as follows (I added the last 3 lines after
> the p2 self-provisioning of the product (the rest of the config.ini is
> generated by PDE headless build); if I specify this config.ini as a
> template, p2 does not correctly self-provision the product, as it does
> not use the simpleconfigurator):
> #Product Runtime Configuration File
> osgi.splashPath=platform:/base/plugins/sc.viper.ide
> eclipse.application=org.eclipse.ui.ide.workbench
> eclipse.product=sc.viper.ide.IDE
> osgi.bundles=org.eclipse.equinox.simpleconfigurator@1:start
> org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
> osgi.bundles.defaultStartLevel=4
> org.eclipse.update.reconcile=false
> eclipse.p2.data.area=../p2
> eclipse.p2.profile=SDKProfile
> The javax.servlet 2.30.v200806031603 is located within the plugins
> directory of my rcp product and it is listed within the bundles.info
> file of the simple configurator as:
> javax.servlet,2.3.0.v200806031603,file:plugins/javax.servlet _2.3.0.v200806031603.jar,4,false
Moving to the Equinox newsgroup.
~ Chris
FUDForum. Page generated in 0.03959 seconds
