An internal error occurred during: "Transform Model". [message #120103] |
Wed, 18 April 2007 06:08  |
Originally posted by: evaandoli.dodo.com.au
Just started getting the following error while transforming from .gmfmap to
..gmfgen
Any clues why ? RuleConductor is in the ecore and genmodels (its the top
level object if that helps).
java.lang.IllegalStateException: Can't find genClass for class
'RuleConductor' in package visualratingmodel
org.eclipse.gmf.internal.bridge.genmodel.GenModelMatcher.fin dGenClass(GenModelMatcher.java:82)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.findGenClass(DiagramGenModelTransformer.java:750)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.process(DiagramGenModelTransformer.java:267)
org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer. transform(MappingTransformer.java:30)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModelOperation$2.process(TransformToGenModelOperation.java: 371)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModelOperation$1.run(TransformToGenModelOperation.java:282)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
eclipse.buildId=I20070222-0951
java.version=1.6.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -launcher C:\apps\wipJEE\eclipse\eclipse.exe -name
Eclipse -startup
C:\apps\wipJEE\eclipse\plugins\org.eclipse.equinox.launcher_ 1.0.0.v20070208a.jar
Command-line arguments: -os win32 -ws win32 -arch x86 -launcher
C:\apps\wipJEE\eclipse\eclipse.exe -name Eclipse -startup
Error
Wed Apr 18 20:03:40 EST 2007
FUDForum. Page generated in 0.05928 seconds
