Home » Language IDEs » C / C++ IDE (CDT) » definedSymbols
definedSymbols [message #120079] Wed, 08 September 2004 06:14
hi!
hi!
Is it possible to add "built-in" options (e.g.: --entry=_start)in
'definedSymbols' type of option? If I write only "-e", this doesn't seem
to work!
I am able to add its value manually when running the toolchain but want to
know if it can be given built-in - user can't add/delete it.
Another observation is when I "Run.." 'Runtime Workbench' to test my
managed build toolchain - each time the include paths get added. If I'm
testing it 3-4 times - those many times the include paths get added. This
is not observed with "Archive [library ]include paths". Is there any
specific reason for this - because after a few tries there is either a
stackdump or out of memory error?
This error is eliminated after a new project is created or all the
repeated paths are manually deleted.
Any solutions greatly appreciated.
thanks and regards,
Monali
Previous Topic:Adding a new option type
Next Topic:Using gcc discovery scanner with gcc cross compiler within a tool chain
Current Time: Thu Jul 17 22:20:05 EDT 2025
Powered by FUDForum. Page generated in 0.02642 seconds
