Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Ecore Tools] Treerouter for inheritance relationships?
[Ecore Tools] Treerouter for inheritance relationships? [message #120004] Fri, 25 April 2008 05:40 Go to next message
Originally posted by: joerg.von.frantzius.artnology.com
according to https://bugs.eclipse.org/bugs/show_bug.cgi?id=215748 there
should be a "Treerouter" for inheritance relationships. I understand
this as a way of making it possible to collapse inheritance
relationships to the same superclass into a single visible triangle,
instead of having one triangle for each relationship. The bug says that
this should be done in release 0.8M6, but using that one I still get
those multiple triangles...
Does anybody know whether the fix really made it into the build, or
maybe I simply didn't understand the bug right?
Jörg
Re: [Ecore Tools] Treerouter for inheritance relationships? [message #120033 is a reply to message #120004] Fri, 25 April 2008 06:12 Go to previous messageGo to next message
Jörg,
You need to manually set the Tree routing style (through the
"Appearance" tab in the Properties View) : usually this routing type is
not proposed (for EReference links for example), and the fix was to
enable it.
However, you are probably right, this should be the default one : we
fixed it, and should available for the next milestone.
Jacques
JJörg von Frantzius a écrit :
> Jörg
Re: [Ecore Tools] Treerouter for inheritance relationships? [message #120046 is a reply to message #120033] Fri, 25 April 2008 06:25 Go to previous message
Thanks Jaques!
Jacques LESCOT schrieb:
> Jörg,
> is not proposed (for EReference links for example), and the fix was to
> enable it.
> Jacques
>> there should be a "Treerouter" for inheritance relationships. I
>> understand this as a way of making it possible to collapse
>> inheritance relationships to the same superclass into a single
>> visible triangle, instead of having one triangle for each
>> relationship. The bug says that this should be done in release 0.8M6,
>> but using that one I still get those multiple triangles...
>> Thanks,
>> Jörg
Re: [Ecore Tools] Treerouter for inheritance relationships? [message #617910 is a reply to message #120004] Fri, 25 April 2008 06:12 Go to previous message
Jörg,
enable it.
Jacques
> Jörg
Re: [Ecore Tools] Treerouter for inheritance relationships? [message #617911 is a reply to message #120033] Fri, 25 April 2008 06:25 Go to previous message
Thanks Jaques!
> Jörg,
> enable it.
> Jacques
>> Thanks,
>> Jörg
Previous Topic:[Ecore Tools] Treerouter for inheritance relationships?
Next Topic:Re: Still interested in mentorship
Current Time: Mon Jul 21 22:13:13 EDT 2025
Powered by FUDForum. Page generated in 0.03312 seconds
