Unable to connect Integrated Agent Controller [message #119937] |
Thu, 27 December 2007 11:48  |
Originally posted by: aciervo.jetlab.com
I'm using Eclipse 3.3.1.1 and just installed TPTP 4.4.0.3 to try and do
some
profiling. I'm using Sun JDK 1.5.0_06.
Integrated Agent Controller is enabled.
To profile a Java application locally, I would like use Integrated Agent
Controller instead of the Agent Controller.
I Click Run > Profile.... The Profiling wizard opens.
I select Java Application.
I turn to the Monitor tab and I select: "java profiling - JRE 1.5"
If I test availibity, I have this message:
"Error: Unable to connect to the Agent Controller.Timeout while waiting
for connection to complete"
Also if I submit 'Profile' button.
With netstat command I see that the connection localhost:10200 ESTABLISHED
Where is the problem?
Assunta
FUDForum. Page generated in 1.12948 seconds
