in M5 class disappear? [message #119906] |
Mon, 24 November 2003 05:30  |
On M5 I get several exceptions like the following:
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jface/text/ITextViewer
at java.lang.Class.getDeclaredConstructors0(Native Method)
it happens in some plugins and CDT and this problem not occur on M4
is the problem in my environment only or is an expected behavior ?
thanks,
Luca
Re: in M5 class disappear? [message #120011 is a reply to message #119943] |
Mon, 24 November 2003 08:25   |
Henning Riedel wrote:
> If you had read the changelist of Eclipse 3.0M5, you would know, that the
> Eclipse API has undergone major API changes. This changes will break almost
> all plugins.
I read that on "Eclipse Project Draft 3.0 plan posted", but I have no
warnings found about incompatible changes between M4 and M5, maybe they
are in the build notes?
> CDT1.2.0 is for Eclipse 2.1.x and Eclipse 3.0 up to M4 only.
CDT 1.2.0 doesn't work for other reasons in M4 too.
I will wait until CDT will work on 3.0, in the meanwhile if someone have
oher hacks to let it work under M5 are wellcome!
thanks again,
Luca
>>> !STACK 0
>>> thanks,
>>> Luca
>> I experienced a similar problem with the X-men plugin (in that case it
>> was the org/eclipse/jface/text/source/SourceViewerConfiguration class.
>> I solved it by adding the jface-text plugin to the list of the
>> required plugins of the X-Men plugin.
>> I.e.:
>> Open plugin.xml in the folder of the plugin and add a line under
>> <requires>: <import plugin="org.eclipse.jface.text"/>
>> I don't know if this is a problem or a planned change to the
>> plugin-descriptor.
>> HTH
>> Christoph
Re: in M5 class disappear? [message #122788 is a reply to message #120011] |
Thu, 27 November 2003 17:38  |
Originally posted by: dschaefe.ca.ibm.com
Yes, the changes in Eclipse 3.0 M5 were pretty dramatic. We have now caught
up and have released an M5 version of CDT 2.0 that will (at least) run in
E3.0 M5.
Doug
>> almost all plugins.
> thanks again,
> Luca
>>>> !STACK 0
>>>> thanks,
>>>> Luca
>>> Hi,
>>> I.e.:
>>> plugin-descriptor.
>>> HTH
>>> Christoph
FUDForum. Page generated in 0.03549 seconds
