Home » Language IDEs » C / C++ IDE (CDT) » code complete...completly confused??
code complete...completly confused?? [message #119900] Tue, 07 September 2004 14:06 Go to next message
Originally posted by: noyoucannothavemyemail.foomanchoo.com
This is pretty much as simple as it gets....
#include <string>
int main(int argc, char *argv[])
string str;
str. <HIT CTRL-SPACE>
brings up..no functions..and instead gives me a list of stuff like:
__codecvt_ok;
PTHREAD_CANCEL_ASYNCHRONOUS
any thoughts what could be wrong?
Re: code complete...completly confused?? [message #119966 is a reply to message #119900] Tue, 07 September 2004 14:58 Go to previous messageGo to next message
Dan,
Do you have the includes paths and defined symbols for the compiler
setup? The scanner relies on those in order to understand what it finds
in the compiler-supplied header files. Does your code specify that it is
using the namespace 'std'. If not, then I suspect that you will get
inconsistent content assist results (not to mention compiler errors).
Sean
> #include <string>
> string str;
> __codecvt_ok;
Re: code complete...completly confused?? [message #120685 is a reply to message #119966] Fri, 10 September 2004 17:23 Go to previous messageGo to next message
sorry I should have specified the project type...
The project is a Standard Make, meaning the make file defines the correct
include paths, etc.. right??
In this case does the parser not use the include paths defined by the make
files?
I also tried explicity specifying the name space as well to no avail..
"Sean Evoy" <sevoy@ca.ibm.com> wrote in message
news:chl059$4hu$2@eclipse.org...
> Dan,
> Sean
> > #include <string>
> > string str;
> > __codecvt_ok;
Re: code complete...completly confused?? [message #120695 is a reply to message #120685] Fri, 10 September 2004 17:45 Go to previous messageGo to next message
Originally posted by: ddaoust.ca.ibm.com
This program does not compile at the string declaration, since you do not
have the proper namespace.
I created a managed make project with a main.cpp that contains:
#include <string>
using namespace std;
string str;
str.
I do a build (so that the compiler builtins are discovered). Then a
content assist on the str. provides a long list of completions.
- Dave
"dan" <noyoucannothavemyemail@foomanchoo.com> wrote in message
news:cht5p2$4ph$1@eclipse.org...
> files?
> > Dan,
> > Sean
> > > #include <string>
> > > string str;
> > > __codecvt_ok;
Re: code complete...completly confused?? [message #120902 is a reply to message #120695] Mon, 13 September 2004 15:06 Go to previous message
Odd, I also tried that...still have a failure..
However..I found that in the my DEBUG folder, eclipse has marked the file:
main.d as having an error (I believe this is auto-generated by
eclipse..right?)
specifically the error is on this line...:
main.d #define __VERSION__ "2.96 20000731 (Red Hat Linux 7.3 2.96-113)"
Im guessing...I need a newer version of make? or gcc?
typeing make --version, yields 3.79.1
and gcc --version, yeilds 2.96
"David Daoust" <ddaoust@ca.ibm.com> wrote in message
news:cht6tq$68q$1@eclipse.org...
> #include <string>
> string str;
> str.
> - Dave
correct
make
> > files?
> > > Dan,
finds
is
> > > Sean
> > > > #include <string>
> > > > string str;
> > > > __codecvt_ok;
Previous Topic:debugging error
Next Topic:Eclipse , MinGW Developer Studio and Dev-Cpp
Current Time: Thu Jul 17 22:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.09084 seconds
