Home » Archived » BIRT » XPathChoosePage
XPathChoosePage [message #119890] Mon, 30 January 2006 10:13 Go to next message
Originally posted by: jan.tanis.coas.com
As stated before I use the XML ODA UI as example. I stripped it down.
But when pressing finished it asks for XPathChoosePage. That class is
never refferenced in any of my files. It isnt mentioned in the
plugin.xml either. Is calling this class a standard operation for such
ODA UI plugin or is it something else? Can someone please provide me
with some information about this, I'm running out on it. Your help is
most appreciated.
Thanks and regards, Jan.
Re: XPathChoosePage [message #120008 is a reply to message #119890] Mon, 30 January 2006 11:31 Go to previous messageGo to next message
------=_NextPart_000_0456_01C62577.80602B80
Content-Type: text/plain;
charset="iso-8859-1"
Jan,
Are you sure that XPathChoosePage class is not in the plugin.xml file =
of your plugin? In the out-of-the-box XML driver's UI plugin =
(org.eclipse.birt.report.data.oda.xml.ui), this class is listed in the =
plugin.xml's declaration of the odadatasource extension:
<odaDataSetUI id=3D"org.eclipse.birt.report.data.oda.xml.dataSet" =
addsDataSetParametersPage =3D "false">
<newDataSetWizard =
class=3D" org.eclipse.birt.report.data.oda.xml.ui.wizards.XmlDataSetWi zard=
<dataSetEditorPage =
class=3D" org.eclipse.birt.report.data.oda.xml.ui.wizards.XmlDataSetSe lect=
ionPage"=20
displayName=3D"XML DataSet" name=3D"selectColumns"/>
class=3D" org.eclipse.birt.report.data.oda.xml.ui.wizards.XPathChooseP age "=
displayName=3D"Table Mapping" name=3D"selectColumns"/>
class=3D" org.eclipse.birt.report.data.oda.xml.ui.wizards.ColumnMappin gPag=
e" displayName=3D"Column Mapping" name=3D"selectColumns"/>
</odaDataSetUI>
--=20
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Jan Tanis" <jan.tanis@coas.com> wrote in message =
news:drlaf9$bur$1@utils.eclipse.org...
>=20
> As stated before I use the XML ODA UI as example. I stripped it down.=20
> But when pressing finished it asks for XPathChoosePage. That class is=20
> never refferenced in any of my files. It isnt mentioned in the=20
> plugin.xml either. Is calling this class a standard operation for such =
> ODA UI plugin or is it something else? Can someone please provide me=20
> with some information about this, I'm running out on it. Your help is=20
> most appreciated.
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1528" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Jan,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Are&nbsp; you sure that XPathChoosePage =
class is=20
not in the plugin.xml file of your plugin? In the out-of-the-box XML =
driver's UI=20
plugin (org.eclipse.birt.report.data.oda.xml.ui), this class is listed =
in the=20
plugin.xml's declaration of the odadatasource extension:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV>
<P><FONT face=3DArial size=3D2>&lt;odaDataSetUI=20
addsDataSetParametersPage =3D=20
"false"&gt;<BR>&lt;newDataSetWizard=20
"/&gt;<BR>&lt;dataSetEditorPage=20
ionPage"=20
<BR>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; displayName=3D"XML DataSet"=20
name=3D"selectColumns"/&gt;</FONT></P>
<P><FONT face=3DArial size=3D2><STRONG>&lt;dataSetEditorPage=20
<BR>&nbsp;&nbsp;&nbsp;=20
&nbsp;&nbsp;&nbsp; displayName=3D"Table Mapping"=20
name=3D"selectColumns"/&gt;</STRONG></FONT></P>
<P><FONT face=3DArial size=3D2>&lt;dataSetEditorPage=20
e"=20
displayName=3D"Column Mapping"=20
name=3D"selectColumns"/&gt;<BR>&lt;/odaDataSetUI&gt; </FONT></P></DIV>
<DIV><BR><FONT face=3DArial size=3D2>-- <BR>Gary Xue<BR>Actuate =
Corporation -=20
Product Development<BR>BIRT Committer</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Jan Tanis" &lt;</FONT><A=20
href=3D"mailto:jan.tanis@coas.com"><FONT face=3DArial=20
size=3D2>jan.tanis@coas.com</FONT></A><FONT face=3DArial size=3D2>&gt; =
wrote in=20
message </FONT><A href=3D"news:drlaf9$bur$1@utils.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:drlaf9$bur$1@utils.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>&gt; Hi,<BR>&gt; =
<BR>&gt; As=20
stated before I use the XML ODA UI as example. I stripped it down. =
<BR>&gt; But=20
when pressing finished it asks for XPathChoosePage. That class is =
<BR>&gt; never=20
refferenced in any of my files. It isnt mentioned in the <BR>&gt; =
plugin.xml=20
either. Is calling this class a standard operation for such <BR>&gt; ODA =
UI=20
plugin or is it something else? Can someone please provide me <BR>&gt; =
with some=20
information about this, I'm running out on it. Your help is <BR>&gt; =
most=20
appreciated.<BR>&gt; <BR>&gt; Thanks and regards, =
Jan.</FONT></BODY></HTML>
------=_NextPart_000_0456_01C62577.80602B80--
Re: XPathChoosePage [message #120643 is a reply to message #120008] Tue, 31 January 2006 00:55 Go to previous message
Hi Gary,
Yes, I'm sure of that. Here is my current plugin.xml:
<?eclipse version="3.0"?>
<plugin
id="org.eclipse.birt.report.data.oda.soap.ui"
name="BIRT SOAP UI Plug-in"
version="2.0.0"
provider-name="COAS Software Systems BV"
class="org.eclipse.birt.report.data.oda.soap.ui.UiPlugin">
<runtime>
<library name="soap-oda-ui.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.birt.report.data.oda.soap"/>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.birt.report.designer.ui"/>
<import plugin="org.eclipse.birt.report.model"/>
<import plugin="org.eclipse.birt.core"/>
<import plugin="org.eclipse.datatools.connectivity.oda"/>
</requires>
<extension
point="org.eclipse.birt.report.designer.ui.odadatasource">
<odaDataSourceUI id="org.eclipse.birt.report.data.oda.soap">
<newDataSourceWizard
class=" org.eclipse.birt.report.data.oda.soap.ui.wizards.XmlDataSour ceConnectionWizard "/>
<dataSourceEditorPage
class=" org.eclipse.birt.report.data.oda.soap.ui.wizards.XmlDataSour cePage "
displayName="%oda.soap.datasource"
name="selectFolder"
path="/"/>
</odaDataSourceUI>
<odaDataSetUI id="org.eclipse.birt.report.data.oda.soap.dataSet"
addsDataSetParametersPage = "false">
<newDataSetWizard
class=" org.eclipse.birt.report.data.oda.soap.ui.wizards.XmlDataSetW izard "/>
<dataSetEditorPage
class=" org.eclipse.birt.report.data.oda.soap.ui.wizards.XmlDataSetS electionPage "
displayName="%oda.soap.dataset"
name="selectColumns"/>
</odaDataSetUI>
</extension>
</plugin>
Gary Xue wrote:
> Jan,
> <odaDataSetUI id="org.eclipse.birt.report.data.oda.xml.dataSet"
> <newDataSetWizard
> class=" org.eclipse.birt.report.data.oda.xml.ui.wizards.XmlDataSetWi zard "/>
> <dataSetEditorPage
> class=" org.eclipse.birt.report.data.oda.xml.ui.wizards.XmlDataSetSe lectionPage "
> displayName="XML DataSet" name="selectColumns"/>
> *<dataSetEditorPage
> class=" org.eclipse.birt.report.data.oda.xml.ui.wizards.XPathChooseP age "
> displayName="Table Mapping" name="selectColumns"/>*
> <dataSetEditorPage
> class=" org.eclipse.birt.report.data.oda.xml.ui.wizards.ColumnMappin gPage "
> displayName="Column Mapping" name="selectColumns"/>
> </odaDataSetUI>
> Gary Xue
> BIRT Committer
> "Jan Tanis" <jan.tanis@coas.com <mailto:jan.tanis@coas.com>> wrote in
> message news:drlaf9$bur$1@utils.eclipse.org...
> > Hi,
> > most appreciated.
Previous Topic:xml datasource & sub reports
Next Topic:Relative path for design file
Current Time: Fri Jul 18 09:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.04490 seconds
