Home » Language IDEs » Java Development Tools (JDT) » inspecting local variables
inspecting local variables [message #119866] Mon, 24 November 2003 03:07 Go to next message
Originally posted by: xxx.esg.de
Hi all,
seems to me that I posted in the wrong (platform) group before. But
still have this question.
Doing a remote debugging I try to inspect local variables. I get the
message "xxx cannot be resolved". Is it a general restriction for
debugging or do I miss something in using the debugger correctly?
I have not found more information on the Eclipse site.
Thanks in advance
Wolfgang R.
Re: inspecting local variables [message #120186 is a reply to message #119866] Mon, 24 November 2003 10:39 Go to previous messageGo to next message
Performing expression evaluations requires that the workspace have the
associated source/projects, such that the expressions can be compiled. When
debugging remotely, you may not have this? (I need more details to know for
sure).
Darin
<xxx@esg.de> wrote in message news:bpse7a$kmv$1@eclipse.org...
> Hi all,
> Thanks in advance
> Wolfgang R.
Antwort: Re: inspecting local variables [message #120298 is a reply to message #120186] Mon, 24 November 2003 12:24 Go to previous messageGo to next message
Hi Darin,
as an example. I have a breakpoint within the EventQueue class at the
first if block.
Now I'm not able to either evaluate src or event.getSource() . It's
telling me
that 'src cannot be resolved'. It seems not to depend on remote debugging
only.
Wolfgang R.
protected void dispatchEvent(AWTEvent event) {
Object src = event.getSource();
if (event instanceof ActiveEvent) {
// This could become the sole method of dispatching in time.
setCurrentEventAndMostRecentTimeImpl(event);
((ActiveEvent)event).dispatch();
} else if (src instanceof Component) {
Re: Antwort: Re: inspecting local variables [message #120359 is a reply to message #120298] Mon, 24 November 2003 15:00 Go to previous messageGo to next message
now I found it in other threads. Used a rt.jar without the required
debug info.
Thanks anyway
Wolfgang R.
xxx@esg.de wrote:
> Hi Darin,
> first if block.
> telling me
> only.
> Thanks
> Wolfgang R.
Antwort: Re: inspecting local variables [message #120697 is a reply to message #120186] Tue, 25 November 2003 03:07 Go to previous messageGo to next message
Hi Darin,
isn't it worth to put this one to the online-help/faq/wiki ?
http://dev.eclipse.org/newslists/news.eclipse.tools/msg56087 .html
Wolfgang R.
Re: Antwort: Re: inspecting local variables [message #121733 is a reply to message #120697] Tue, 25 November 2003 11:56 Go to previous message
I have no problem with you adding this to the wiki
Darins
<xxx@esg.de> wrote in message news:bpv2kj$hpf$1@eclipse.org...
> Hi Darin,
> Regards
> Wolfgang R.
Previous Topic:including other dependencies?
Next Topic:[bug] M5: refactoring anon -> nested class
Current Time: Fri Jul 18 04:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.13133 seconds
