Home » Eclipse Projects » Remote Application Platform (RAP) » Messages.get() within IRunnableWithProgress
Messages.get() within IRunnableWithProgress [message #119831] Tue, 27 January 2009 13:14 Go to next message
I have a wizard that does some long runnning operation in method
"performFinish".
This is currently doen with the following call:
getContainer().run(true, true, new IRunnableWithProgress() {
public void run(IProgressMonitor monitor) throws InvocationTargetException {
monitor.beginTask(Messages.get().myText, IProgressMonitor.UNKNOWN);
The call to Messages.get() raises the following exception:
java.lang.IllegalStateException: No context available outside of the request
service lifecycle.
Is there any solution to this or am I doing something wrong?
Markus
Re: Messages.get() within IRunnableWithProgress [message #119988 is a reply to message #119831] Thu, 29 January 2009 05:40 Go to previous messageGo to next message
Markus,
your code tries to access session-information but isn't run from the
UI thread (the only thread that has a session context associated by
default).
The soltion is to wrap your code in a Runnable and have it executed
by UICallBack#runNonUIThreadWithFakeContext().
Please also see this thread:
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg01311.html
HTH
Rüdiger
Markus Krüger wrote:
> "performFinish".
> service lifecycle.
> Markus
Re: Messages.get() within IRunnableWithProgress [message #120170 is a reply to message #119988] Fri, 30 January 2009 08:08 Go to previous messageGo to next message
can I always do this in the class Messages of my plugin?
Markus
"R
Re: Messages.get() within IRunnableWithProgress [message #120314 is a reply to message #120170] Tue, 03 February 2009 10:12 Go to previous messageGo to next message
Markus,
if you read the method signature, you will know the answer: very
unlikely. The method requires a disply to be passed in and this
isn't usually available in your Messages implementation.
HTH
Rüdiger
> Markus
> "Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
> news:gls12f$4dv$1@build.eclipse.org...
>> Markus,
>> your code tries to access session-information but isn't run from the UI
>> thread (the only thread that has a session context associated by default).
>> The soltion is to wrap your code in a Runnable and have it executed by
>> HTH
>> Rüdiger
>>> Hi,
>>> "performFinish".
>>> request service lifecycle.
>>> Regards,
>>> Markus
Re: Messages.get() within IRunnableWithProgress [message #120434 is a reply to message #120314] Wed, 04 February 2009 08:39 Go to previous message
Hi R
Previous Topic:Changing default Font / Theming
Next Topic:Clipboard workaround
Current Time: Sun Jul 27 03:09:55 EDT 2025
Powered by FUDForum. Page generated in 0.17635 seconds
