Home » Eclipse Projects » Equinox » Conditional dependencies in manifest?
Conditional dependencies in manifest? [message #119814] Mon, 20 October 2008 13:46 Go to next message
We need to handle our log4j dependency for 3.2.2 and 3.3+. The Eclipse
SDKs are different for lo4gj - 3.2 comes with (or via WST) bundle
"org.apache.jakarta_log4j" whereas 3.3+ with "org.apache.log4j". To avoid
additional install steps for our product, our thinking was employing some
sort of conditional dependency in our bundle manifest: if not
"org.apache.log4j", then "org.apache.jakarta_log4j".
I don't see conditional dependencies for OSGi, although ideas have been
propose. I don't see how "optional" would work given that we have a hard
dependency on Log4j.
Is this possible? Another option?
Thanks.
Re: Conditional dependencies in manifest? [message #119827 is a reply to message #119814] Mon, 20 October 2008 13:57 Go to previous messageGo to next message
I'd manage the dependency using Import-Package instead of Require-Bundle,
that way you don't care which bundle is installed and giving you the various
log4j packages. If that's what you're doing already can you give a bit more
detail.
-Simon
"Chris W" <chris@firestruck.com> wrote in message
news:f18abc5b6a411dc1c013d31af03f200e$1@www.eclipse.org...
> Thanks.
Re: Conditional dependencies in manifest? [message #119853 is a reply to message #119827] Mon, 20 October 2008 20:28 Go to previous messageGo to next message
Thanks Simon.
I believe that would work, but, what I left out, is that we have our own
appender and also log to Eclipse's log, see we require a buddy connection.
Could I import "org.apache.log4j" and have two separate buddy entries -
one for "org.apache.log4j" and the other for "org.apache.jakarta_log4j"?
Eclipse-RegisterBuddy: org.apache.log4j
Re: Conditional dependencies in manifest? [message #119879 is a reply to message #119853] Tue, 21 October 2008 12:48 Go to previous message
Originally posted by: ekkehard.gentz-software.de
Chris W schrieb:
> Thanks Simon.
> connection. Could I import "org.apache.log4j" and have two separate
> buddy entries - one for "org.apache.log4j" and the other for
as Simon says,
you should use package-import
and your appender should work without buddy,
try a Fragment Bundle - I'm using a Fragment Bundle per ex. to make
extensions of LogBack classes which should be similar to Log4J
you should use Buddys only if there's no other standard
osgi way to solve the requirement
BTW: I'll report exactly about these Fragment bundles in my next blog
about "Logging in OSGI Enterprise apps" (http://ekkes-corner.org)
ekke
Previous Topic:Thanks: how should I use API's manipulate bundles as in the console?
Next Topic:headless eclipse - classpath issues
Current Time: Thu Jul 17 21:43:39 EDT 2025
Powered by FUDForum. Page generated in 0.29243 seconds
