Home » Newcomers » Newcomers » how to know if JRE is installed on linux
how to know if JRE is installed on linux [message #119796] Fri, 25 November 2005 15:45 Go to next message
Originally posted by: guyen000.hotmail.com
Hi, I downloaded JRE1.4.2 and installed it on my Linux Ubuntu.
But it doesn't give me any feedback whether the installation was
successful or not. Just showed me the command line after executing the
install file.
Is there a way to know if JRE is successfully installed or not? Thanks!
Re: how to know if JRE is installed on linux [message #119824 is a reply to message #119796] Fri, 25 November 2005 17:26 Go to previous message
Guyen,
You can use the command "which java" to tell you which version of java
shows up on your path first. If that returns something, that means java
is available. Next try "java --version" to determine if the one you
expect (1.4.2) is the one that's being run.
Hope this helps,
- Jeff
> install file. Is there a way to know if JRE is successfully installed or
> not? Thanks!
Previous Topic:Get shortcut to run my Ant target
Next Topic:How to include "resource" files when running a java file as a J2ME MIDlet?
Current Time: Thu Jul 17 23:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.11902 seconds
