Home » Modeling » GMF (Graphical Modeling Framework) » How can I select an element in the canvas?
How can I select an element in the canvas? [message #119680] Mon, 16 April 2007 10:31 Go to next message
Originally posted by: kalin.nakov.gmail.com
I want to select an element in the canvas by means of Java code. I
googled out the method SelectInDiagramHelper.selectElement(someView).
But unfortunately I have only a org.eclipse.gmf.runtime.notation.Node
class instance which points to the correct diagram node. The difficult
question is how can I convert that Node object to a
org.eclipse.gmf.runtime.notation.View object so that I can finally
select it?
Thanks in advance,
Kalin
Re: How can I select an element in the canvas? [message #119692 is a reply to message #119680] Mon, 16 April 2007 10:44 Go to previous messageGo to next message
Sorry for the stupid question, it appears that Node extends View so that
I can directly select the node. Unfortunately now that assertion in
SelectInDiagramHelper.selectElement() fails:
Assert.isTrue(diagramEditor.getDiagram().equals(view.getDiag ram()));
It appears that the selected element's diagram is different from the
current diagram. That is strange, because on the previous line I have
explicitly called
EditUIUtil.openEditor((EObject) diagram.getContents().get(0));
It appears that the editor is fooled out and no matter that the newly
open diagram is visible and active, it seems that the GMF framework
still thinks the old diagram is active instead of the new one.
How can I force the framework to refresh it's state so that the newly
open diagram will become active?
Kalin
Kalin Nakov wrote:
> select it?
> Thanks in advance,
> Kalin
Re: How can I select an element in the canvas? [message #119820 is a reply to message #119692] Mon, 16 April 2007 14:52 Go to previous messageGo to next message
That should be simple, I just want to open a diagram and select an
element in it. The obvious sequence XXXDiagramEditorUtil.openDiagram()
-> SelectInDiagramHelper.selectElement() does not work - diagram is
visually open, but is not set as the current active digram. What is the
correct sequence to use?
> explicitly called
> Kalin
> Kalin Nakov wrote:
>> select it?
>> Thanks in advance,
>> Kalin
Re: How can I select an element in the canvas? [message #119833 is a reply to message #119820] Tue, 17 April 2007 02:25 Go to previous messageGo to next message
I have more information on the GMF bug. Here it is:
XXXDiagramEditorUtil.openDiagram(r);
IEditorPart editorPart =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActiveEditor();
diagramEditor = (DiagramEditor) editorPart;
The openDiagram() method opens the diagram, I see that in the editor,
but unfortunately the getActivePage() method returns the page which was
active before opening the diagram. I tried to check the number of pages
in the active workbench window, but it was not affected by the
openDiagram method. I find it impossible to retrieve the new active page
after opening a diagram, it seems that some internal structures in GMF
are not refreshed.
>> that I can directly select the node. Unfortunately now that assertion
>> in SelectInDiagramHelper.selectElement() fails:
>> explicitly called
>> Thanks,
>> Kalin
>> Kalin Nakov wrote:
>>> Hi,
>>> difficult question is how can I convert that Node object to a
>>> select it?
>>> Thanks in advance,
>>> Kalin
Re: How can I select an element in the canvas? [message #119912 is a reply to message #119833] Tue, 17 April 2007 06:12 Go to previous message
Hello Kalin,
> page after opening a diagram, it seems that some internal structures
> in GMF are not refreshed.
You can easily track the result of open editor operation: EditUIUtil.openEditor
contains following line: return editorPart != null;
So, result of ???DiagramEditorUtil.openDiagram() will be "true" if editor
was successfully openned and available form eclipse API (IWorkbenchPage.getEditorReferences())
Alex Shatalin
Previous Topic:GMF(Callisto) 1.0.3: org.eclipse.emf.validation.ocl requires "org.eclipse.ocl.ecore" ????
Next Topic:Problem creating Editor: Invocation Target Exception
Current Time: Mon Jul 07 19:07:44 EDT 2025
Powered by FUDForum. Page generated in 0.04142 seconds
