Is JRE 1.6.0.3 = Java 6 [message #119597] |
Mon, 17 December 2007 03:49  |
Originally posted by: lordrisborik.gmail.com
Well ,
It says TPTP works with JAVA5 . Eclipse is quite independant development
platform . It can take almost everything with it , but It uses Local JRE
you installed before . We have to specify PATH of JRE for Eclipse . If I
am using JRE 1.6.0.3 , is It equal to Java 6 ? Please Direct me , I'm
confused .
Re: Is JRE 1.6.0.3 = Java 6 [message #119845 is a reply to message #119597] |
Sun, 23 December 2007 00:19  |
Originally posted by: n.sherlock.gmail.com
Tom wrote:
> Well , It says TPTP works with JAVA5 . Eclipse is quite independant
> development platform . It can take almost everything with it , but It
> uses Local JRE you installed before . We have to specify PATH of JRE
> for Eclipse . If I am using JRE 1.6.0.3 , is It equal to Java 6 ?
> Please Direct me , I'm confused .
TPTP actually seems to work with Java 6, the developers just don't
guarantee that everything will work properly as they don't develop
against Java 6.
Nicholas Sherlock
FUDForum. Page generated in 0.04797 seconds
