Home » Language IDEs » C / C++ IDE (CDT) » Using gcc discovery scanner with gcc cross compiler within a tool chain
Using gcc discovery scanner with gcc cross compiler within a tool chain [message #119562] Mon, 06 September 2004 05:42 Go to next message
I'm trying to write a toolchain (managed build) which uses a gcc cross
compiler (so cdt doesn't call "gcc" but "ppc-amigaos-gcc" to compile). If I
use DefaultGCCScannerInfoCollector for my newly created target, I only get
the include paths for the host gcc compiler but not for the target compiler.
Is there a possibilty to tell the discovery scanner to use a different
command? (it iss possible to do this manually within standard makefile
project, but by using the plugin the developer shouldn't care about this).
Thanks in advance!
Ciao,
Sebastian
Re: Using gcc discovery scanner with gcc cross compiler within a tool chain [message #119800 is a reply to message #119562] Tue, 07 September 2004 11:11 Go to previous messageGo to next message
Sebastien,
If you call 'ppc-amigaos-gcc -E -P -v foo.cpp' does the cross compiler
give you a list of valid includes paths and symbols?
Sean
Sebastian Bauer wrote:
> Hello,
> Thanks in advance!
> Ciao,
> Sebastian
Re: Using gcc discovery scanner with gcc cross compiler within a tool chain [message #119826 is a reply to message #119800] Tue, 07 September 2004 11:49 Go to previous messageGo to next message
Sean Evoy wrote:
> Sebastien,
Yes. As said it works if I alter the command within the standard makefile
project manually. But my plugin is a toolchain for the managed build. So for
the scannerInfoCollector property within the my own target I use the
DefaultGCCScannerInfoCollector. But I don't see a possibility to specify a
different compiler command somewhere. So how does CTD know which command to
call?
I must admit, that I haven't understood this issue fully. So for example I
don't exactly know who invokes the gcc call to determine the includes as
DefaultGCCScannerInfoCollector seems only parse the result of an previous
call.
Ciao,
Sebastian
Re: Using gcc discovery scanner with gcc cross compiler within a tool chain [message #119865 is a reply to message #119826] Tue, 07 September 2004 13:05 Go to previous messageGo to next message
Sebastien,
This collection of includes paths and defines from the compiler takes
place when the project info is created/loaded into the MBS. There are
two strategies; dynamic discovery or a fall-back to ahrd-coded entries.
Unfortunately, the MBS is using the default external scanner info
provider which calls 'gcc' for the dynamic bit and I ran out of time to
make this configurable. Specifying an alternative (either by extending
the IManagedScannerInfoCollector interface or specifying it in the
toolchain spec) is on the list of items TODO for 2.1.
All is not lost, though. If you do not specify a
IManagedScannerInfoCollector, the default is to look through the
includes paths and defined symbols in the toolchain specification and
extract any with the 'builtIn' attribute set to true.
Let me know if this helps.
Sean
> Sean Evoy wrote:
>>Sebastien,
> call?
> call.
> Ciao,
> Sebastian
Re: Using gcc discovery scanner with gcc cross compiler within a tool chain [message #119891 is a reply to message #119865] Tue, 07 September 2004 14:01 Go to previous messageGo to next message
Originally posted by: vhirsl.ca.ibm.com
Sebastien,
there is another way to get proper compiler scanner info discovered.
In CDT Preferences, C/C++ -> New Make Projects preference page, Discovery
Options tab you can set Generate scanner info command options for new
projects (this applies to both new standard and managed projects). You
should uncheck 'Use default' radio button and in the next edit field
replace 'gcc' with 'ppc-amigaos-gcc'. Then recreate your project (or
create a new one) and import your files.
Hope this helps,
Vladimir Hirsl
Re: Using gcc discovery scanner with gcc cross compiler within a tool chain [message #120097 is a reply to message #119891] Wed, 08 September 2004 08:21 Go to previous message
Hello Sean and Vladimir,
I think specifing the includes manually with the builtin option is not
possible, because I don't know where the system includes exactly are located
on the users system.
Altering the prefs has the disadvantage, that then the discovery scanner
works only properly for the cross compiler. But I guess at the moment it is
the only possibility until 2.1.0 is out (I'll mention this in the docs).
Thanks for the hint.
Ciao,
Sebastian
Previous Topic:definedSymbols
Next Topic:Problems Opening Editor
Current Time: Thu Jul 17 07:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.07368 seconds
