Home » Archived » BIRT » Using Birt in an RCP application
Using Birt in an RCP application [message #119550] Mon, 30 January 2006 04:35 Go to next message
Originally posted by: nicolas._no.spam_legrain.fr
I'm new to Birt and I want to use it in an Eclipse RCP application.
The only thing I manage to do is running a report and create the resulting
html/pdf file with the RunReport.java example.
I 've search the web but I didn't manage to find any good example or "how to"
for using Birt in an RCP application (only webapp example),
so I have several questions:
1) Is it possible to directly run and print a report on the same action ? If
yes, how?
2) How can I make a preview of a report like in "BIRT RCP report designer"
application? Is it possible with out an application server? Is it possible to use
the server of the Eclipse help system? If yes, how can I do this?
I use Birt 1.0.1. Is birt 2.0 more easy to "test" birt?
thanks for your help.
Re: Using Birt in an RCP application [message #120047 is a reply to message #119550] Mon, 30 January 2006 11:46 Go to previous message
I've understand for question 2. Any ideas for question 1.
nm a écrit :
> resulting html/pdf file with the RunReport.java example.
> "how to" for using Birt in an RCP application (only webapp example),
> ? If yes, how?
> designer" application? Is it possible with out an application server? Is
> it possible to use
Previous Topic:error setting image visibility
Next Topic:Reg:How to set Page Navigation Property for reports
Current Time: Tue Jul 15 03:23:15 EDT 2025
Powered by FUDForum. Page generated in 0.28495 seconds
